Toymods » Tech & Conversions » Question about cutting hole in bonnet for Levin scoop
Levin4Kevin
Sydeny
Question about cutting hole in bonnet for Levin scoop Mon, 09 June 2003 08:28 Go to next message
Need info about cutting hole in AE92 bonnet.
For those that have done this - did you just cut out the same shape and size as original hole and then bend the front and rear edge down and bolt on the scoop. Did you reinforce it (weld where need) for strength.
Panel beater has suggested cutting a larger area from original Levin bonnet (about 6 inches out side the original hole) and then cutting same size hole in my Australian bonnet and welding it in.
I think this is going to cost me heaps and I need to let him know by tomorrow (Tuesday). Kevin Confused
JDM hachi
was adelaide now newcastle
Re: Question about cutting hole in bonnet for Levin scoop Mon, 09 June 2003 23:11 Go to previous messageGo to next message
all i know is that it's probably not a good idea to cut into the bonnets bracing, if you want to see an engineer. if you dont cut the bonnet there should be enough strength without the need to reinforce.
FLYNSX
    flyn
Re: Question about cutting hole in bonnet for Levin scoop Tue, 10 June 2003 15:31 Go to previous messageGo to next message
as soon as u cut any support out of ya bonnet u cant get it enginerred u can cut the metal between ya bracing but not the support of the bonnet frame
tim123c
Re: Question about cutting hole in bonnet for Levin scoop Tue, 10 June 2003 23:39 Go to previous message
I got an AE92 levin bonnet with scoop for sale for $180 if your interested? its white. Very Happy
Previous Topic:NEED car wireing diagram/ Celica w/ 18r-gue
Next Topic:INFO: This is the 18R-GEU EFI thermostat housing!
Current Time: Sun Nov 1 23:36:51 UTC 2026
Total time taken to generate the page: 0.0037050247192383 seconds
