Toymods » Tech & Conversions » oxygen sensor 4AGE
Hirogen
Melbourne, Australia
      WTF is a jabber?
icon5.gif  oxygen sensor 4AGE Tue, 10 June 2003 01:53 Go to next message
Ok, i have a set of extractors on my 4AGE, and its time to put the 02 sensor in, now ive been told that it has to be where all 4 pipes intersect, so it samples exhaust from all cylinders. Is this true? or can i just put it in one of the pipes and have it run just as good? Confused
feral4mr2
Bundaberg, Qld.
Re: oxygen sensor 4AGE Tue, 10 June 2003 02:03 Go to previous messageGo to next message
Freakwell on the original manifold it's at the bottom where it can sample all 4 cylinders..
so i would say it's correct to have it where all 4 join together.
earlyrolla
Re: oxygen sensor 4AGE Tue, 10 June 2003 02:34 Go to previous messageGo to next message
You can place the O2 sensor in any one of the pipes, but doing so you will be running the risk that all cylinders will be operating under identical conditions all the time. If the cylinder that has the O2 sensor runs rich while the others are lean then the computer will lean out the engine to compensate for the rich signal on the O2 sensor hence allowing possible damage to occur on the other cylinders. Seems an unlikely case, but it is possible for a number of reasons.
Better to place it at the join of all four pipes to get an average reading.
Cheers.
Sam
Sydney, Australia
Re: oxygen sensor 4AGE Tue, 10 June 2003 02:46 Go to previous messageGo to next message
The only thing to watch, if it's a one wire sender, that it gets hot enough to operate correctly if it's too far down the exhaust pipe. Otherwise you may have to fit a heated unit.
For what it's worth, I run mine at the 2 -> 1 junction.
sam.
threegeese
Re: oxygen sensor 4AGE Tue, 10 June 2003 08:33 Go to previous message
A lot of aftermarket headers only sample one cylinder. I don't even have an oxy sensor on my 4AG Laughing
Previous Topic:4agZe Cams Specs
Next Topic:5M Timing/Valve Train Rattle
Current Time: Wed Nov 18 10:17:41 UTC 2026
Total time taken to generate the page: 0.0044550895690918 seconds
