Toymods » Tech & Conversions » 3s-gte rwd clutch and flywheel
gabe
3s-gte rwd clutch and flywheel Tue, 10 June 2003 08:42 Go to next message
guys,
have done a heap of searching and still cannot see through all the crap that is thrown around regarding what flywheel and clutch to use when converting a 3sgte to rear wheel drive....
i already have a supra box and 2sbellhousing but need to know wot goes in it
help please
gabe
Re: 3s-gte rwd clutch and flywheel Tue, 10 June 2003 09:02 Go to previous messageGo to next message
This thread is interesting: http://www.toymods.org.au/msgboard/index.php?t=msg &goto=79372&rid=42&S=0c643b306f732f9c5 e5c756a5523a09a
TurboRG
Nor Calif USA
Re: 3s-gte rwd clutch and flywheel Tue, 10 June 2003 22:57 Go to previous messageGo to next message
http://www.toymods.org.au/msgboard/index.php?t=msg &goto=20760&rid=&S=67a216879cc8f75e65e fbb7063627efd
gabe
Re: 3s-gte rwd clutch and flywheel Wed, 11 June 2003 05:11 Go to previous messageGo to next message
so i can either
1. get a custom flywheel made
2. use 3sgte clutch, flywheel and get 5mm machined off the bellhousing
3. use 2s flywheel and go spare redrilling holes....
obviously the custom flywheel route is the better option but if i can get it done cheaper then ill do that.
is the 3sgte flywheel/machining option the next best thing? and are there any other problems with this option??
cheers all.....
oh and ive heard of people using 3sge (st162) flywheel.....will this work??
JustenGT4
Re: 3s-gte rwd clutch and flywheel Wed, 11 June 2003 06:17 Go to previous messageGo to next message
What gen 3SGRE do you have. The 162 flywheel as per all the n/a flywheels only has a six bolt crank.
I had a flywheel made up but only to the same dimensions as a stock Gen II 3SGTE one (but in alloy). All you need to do then is have an extension for the bearing carrier made to get the clutch fork travel sorted. My setup appears to work fine. i didn't need to machine anything off the bellhousing and the input shaft meets the spigot bearing OK (approx 5mm insert) ideally you would still machine the bellhousing to get a deeper fit but seeing the GT4 has no spigot bearing at all i don't see that as a major issue. It's only harmonic you are worried about so it doesn't need much support.
email me direct if you have any more questions
Re: 3s-gte rwd clutch and flywheel Wed, 11 June 2003 07:11 Go to previous messageGo to next message
When fitting a 3S in RWD format, you will need to use a spigot bearing.
TA22-3SGTE
MACKAY
Re: 3s-gte rwd clutch and flywheel Wed, 11 June 2003 10:14 Go to previous messageGo to next message
I've done it both ways with using a 2S flywheel and using the 3SGTE flywheel both way's work as good , Using the 2S flywheel all that needs to be done is to plug and redrill to the 8 bolt pattern and with the 3SGTE flywheel just get the bellhousing milled , Using the 2S flywheel you can use the 2S starter but using the 3SGTE flywheel a different starter needs to be used as the 3sgte flywheel has a larger diameter.
The flywheel off the later 3SFE also has the 8 bolt pattern and can be used.
The 2S and 3SFE flywheel can only be used on the first gen ( ST165 ) as the later motors have larger bolts and a slightly different bolt spacing.
Trevor
gabe
Re: 3s-gte rwd clutch and flywheel Fri, 13 June 2003 13:26 Go to previous messageGo to next message
trevor --> i was thinking, if i use the 3sgte flywheel, the 2s starter will not engage due to the 3sgte's larger diameter right?? so could i slot the starter holes and move the starter?? it only needs to be moved about 4mm outwards.
alternatively - i think i can modify the bellhousing myself to make the starter sit on the other side because it does sit close to the turbo, and if i did this, i could make the starter sit wherever i want-and acommodate any flywheel i wish. it is a complicated job though.
shane --> roger the spigot bearing
[Updated on: Fri, 13 June 2003 13:28]
CelicaRA45
nth ringwood, Victoria
Re: 3s-gte rwd clutch and flywheel Sat, 14 June 2003 03:54 Go to previous messageGo to next message
or you can buy 1 of my rwd 1s that cool 1 did also jamie from sydney did as well its so much easier and less hasle
TA22-3SGTE
MACKAY
Re: 3s-gte rwd clutch and flywheel Sat, 14 June 2003 09:44 Go to previous messageGo to next message
gabe---------- Yes you could slot the holes a bit to move the starter out a bit , I did this myself when I was first doing the conversion using the 2S flywheel and all I had at the time was a 4age starter so I had to slot the holes in a bit for the starter to contact the flywheel and it worked fine but I later picked up a 2S starter and put that on , With the 3SGTE flywheel I used a different starter that bolted straight on but I don't know what the starter is off as I have a fair few starters laying around and have forgotten what their off , I made a turbo manifold to sit the turbo the right way and left the starter on the turbo side and have been running it like this for about three years an have had no trouble with the heat effecting the starter , If you look at some of the N/A cars with extractors you will find the starters are near touching the pipes and don't have trouble .
Trevor
turbocamry
newcastle
Re: 3s-gte rwd clutch and flywheel Mon, 16 June 2003 08:37 Go to previous messageGo to next message
i have a 3SGTE 4wd gearbox, drive shafts, clutch and flywheel for sale sounds alot easyer than all those missions if u ask me
make me a offer!
gabe
Re: 3s-gte rwd clutch and flywheel Mon, 16 June 2003 13:47 Go to previous messageGo to next message
i need to go from w58 supra box to 3sgte so your bellhousing is unsuitable.... Smile
Re: 3s-gte rwd clutch and flywheel Mon, 16 June 2003 13:49 Go to previous messageGo to next message
Glenns' bellhousing will do the trick.
gabe
Re: 3s-gte rwd clutch and flywheel Mon, 16 June 2003 15:14 Go to previous messageGo to next message
can i just ask what is different from a 2s bellhousing and Glenns bellhousing??
purpleminiep
Mentone
Re: 3s-gte rwd clutch and flywheel Mon, 16 June 2003 22:43 Go to previous messageGo to next message
Toby has organised custom flywheels that are made by the trd people in Melbourne. They are about the $660 mark. They allow the 2s bellhousing i think and do not need the release bearing lengthened. He is selling a heap of stuff at the moment so should be easy to find on the forum.
Brad
Re: 3s-gte rwd clutch and flywheel Mon, 16 June 2003 23:21 Go to previous messageGo to next message
gabe wrote on Tue, 17 June 2003 01:14
A whole bunch of work Rolling Eyes
He has the starter and clutch slave on the drivers side away from the turbo.
CelicaRA45
Re: 3s-gte rwd clutch and flywheel Tue, 17 June 2003 05:33 Go to previous message
ALSO GUYS IF YOU NEED A FLY WHEEL MADE LET ME NO THEY ARE CHROM MOLY AND COST ME 475 PLUS A RING GEAR OF 35 PLUS SHIPPING TO WHO EVER WONTS 1 I DONT MAKE ANYTHING OUT OF THIS ONLY HELPING PEOPLE ON THIS SITE ,ALSO YOU CAN HAVE THEM AT 4.0 KILOS OF HEAVIER IF YOU WONT ITS UP TO YOU GUYS AND THEY ARE RWD TYPE NOT FWD .THE BELLHOUSING IS ANOTHER 1 BUT I ONLY GET THEM MADE WHEN PEOPLE ASK ME OR IF I HAVE ASPARE .AND THE GUY CHARGES ME AROUND 350 JUST TO MOVE THE STARTER AND CLUTCH TO THE OTHER SIDE PLUS THE COST OF FINDING A BELLHOUSING IN THE 1ST PLACE ,TOBY HAS 1 FOR 300 SO IF YOU BOUGHT HIS AS AN EXAMPLE IT WOULD COST YOU 650 PLUS POSTAGE
Previous Topic:What box should i use in the 1j cressi
Next Topic:18RGU emissions info needed for RWC
Current Time: Sat Oct 24 05:44:09 UTC 2026
Total time taken to generate the page: 0.0051398277282715 seconds
