Toymods » Tech & Conversions » Boost Gauge Installation - Gt4
Classique71
Colac, Victoria
Boost Gauge Installation - Gt4 Wed, 11 June 2003 09:31 Go to next message
has anyone used the stock boost guage lines to run an aftermarket boost guage in their GT4? Im hoping when i get around to ripping the dash apart to use the vaccum line the stock guage works on to plug into the new guage ..
Semi guessing the boost guage runs off the vaccum line that runs into the cabin via the left hand side hole inside the engine compartment where the loom pokes thru ?
[Updated on: Thu, 12 June 2003 01:32] by Moderator
CrAiGzEE
south of the big smoke
Re: Boost Guage - Gt4 specific Wed, 11 June 2003 09:34 Go to previous messageGo to next message
yeah should work in theory! why the hell didnt that put a decent one in, in the first place!
Classique71
Colac, Victoria
Re: Boost Guage - Gt4 specific Wed, 11 June 2003 09:53 Go to previous messageGo to next message
No idea - but the stock one ( same applies for 205's , supras and MR2's ) are absolutely F-ing useless .. A total and utter waste of precios cabin space they are ..
Its also like why they didnt put a BOV on the gt4's - another pointless Why! A simple bosch one would have done the job
Re: Boost Guage - Gt4 specific Wed, 11 June 2003 10:13 Go to previous messageGo to next message
They did have a BOV on the 205 Very Happy
Classique71
Colac, Victoria
Re: Boost Guage - Gt4 specific Wed, 11 June 2003 10:26 Go to previous messageGo to next message
i stand corrected..
DannyGT4
Toymods Board Member
Re: Boost Guage - Gt4 specific Thu, 12 June 2003 00:11 Go to previous messageGo to next message
stu...
leave the stock boost gauge alone
if you are installing an aftermarket gauge in the GT4 here are some basic instructions for connecting the vacuum line...
at the back of the intake manifold you will find a plugged nipple that is not being used.
remove the rubber plug and insert a vacuum hose of the right diameter - you may need an adaptor to then connect that hose to the smaller line that comes with the boost gauge (depending on what comes with the gauge).
run the line through the firewall grommett beneath the manifold, up under the dash and into the gauge.
wire up the gauge light to the dimmer.
boost gauge now installed!
...and you now have two seperate boost gauges with separate signals in case of failure (albeit one not very accurate Razz)
let me know if you have any problems
Classique71
Colac, Victoria
Re: Boost Guage - Gt4 specific Thu, 12 June 2003 08:20 Go to previous messageGo to next message
I ended up buying a Speco guage - has some adaptors and stuff with it - so ill have a peek for that plug next free moment ..
is it easily accessed ?
DannyGT4
Re: Boost Guage - Gt4 specific Fri, 13 June 2003 01:48 Go to previous messageGo to next message
lol... is anything on the gt4??
its not too bad... you can see it fairly easy and its a tight fit to slip your hand between the manifold and the firewall but should be ok... you might need long pliers or needle nose pliers
i had no major problem
just have a looksee and you should the plug i'm talking about
Re: Boost Gauge Installation - Gt4 Fri, 13 June 2003 08:06 Go to previous messageGo to next message
You need to do this to get easy access to the manifold Very Happy
http://members.iinet.net.au/~shanej/HalfCut/images/P0001563.jpg
turbocamry
newcastle
Re: Boost Gauge Installation - Gt4 Mon, 16 June 2003 09:06 Go to previous messageGo to next message
lmao looks like mine Very Happy
Classique71
Colac, Victoria
Re: Boost Gauge Installation - Gt4 Mon, 16 June 2003 10:55 Go to previous messageGo to next message
ha - well i found the formentioned thing - and can get to it easy enough _ PLUS the convenient grommet Smile Just going to use the one that the heater control cable goes into ( blue thing on mine ) and follow it up thru the dash - THEN if i can get a 12v powersource located - ill hopefully have it in by the weekend - if not tomorrow
DannyGT4
Re: Boost Gauge Installation - Gt4 Tue, 17 June 2003 03:00 Go to previous messageGo to next message
sweet
re: power supply
under the ignition you'll find a heap wires... doh!
there should also be a spare connector (used for fog lights?)
anyway i used this... i think the wires were green (positive) white (negative - dimmer)
wire in the gauge power supply to these and you'll get power to them as per your other gauges
Smile
Classique71
Colac, Victoria
Re: Boost Gauge Installation - Gt4 Tue, 17 June 2003 08:41 Go to previous messageGo to next message
well the guage is in - my hands are bleedin, back aching - and i have one hell of a stress related headache !
Someone told me this would be easy but NOOO - they forgot to consider the GREMLINS that always invade projects like this
Anyway - in a nutshell - i couldnt use the second vac line thats blocked off - hose wasnt big enough - so i spliced in a T peice off one of the other hoses - guage gets the job done - alas having a nightmare of a time fitting it
to install it in the corner near the apillar - i had to remodify the Speco Guage cup to give about another cm of clearance for the wires and hose for the boosg guage - REVERSE the way they screw the mounting brackets, curse at it alot to make it fit. Its in now - just have to wire up the little light as yet.
The car runs at a const and and steady 13PSI of boost at maximum Dial in , and seeing the speco guage is a combined vaccum/boost guage - 19 points of vaccum on idle
http://home.iprimus.com.au/utahraptor/gt4_pics/guagein.jpg
Dunno if this is meant to be right or not - so can someone shed some light on it ..
Anyway - heres a pic of it installed
spectral
Re: Boost Gauge Installation - Gt4 Wed, 18 June 2003 11:05 Go to previous messageGo to next message
You may have found it easier to use the hose off the standard boost sensor mounted on the firewall.
Just T-Piece into the existing hose here: http://www.amberaspley.com/gt4/pics/T_Piece.jpg
Then convert it to the boost gauge hose, using a 1/4" barb with a 3/8" thread, onto a 3/8" collar, then into the standard autometer (in my case) brass adaptor, shown here:
http://www.amberaspley.com/gt4/pics/convertor.jpg
Took around 5 mins to install.
Hope this helps.
[Updated on: Wed, 18 June 2003 11:06]
Classique71
Colac, Victoria
Re: Boost Gauge Installation - Gt4 Wed, 18 June 2003 11:52 Go to previous messageGo to next message
thats basically what i ended up doing in the end - guage works fine now Smile
Tried to go the other way first ( the plugged one ) but found the hose i had wouldnt fit ..
Most of the time taken was in actually PLACING the guage inside the car and getting that fitted right
DannyGT4
Re: Boost Gauge Installation - Gt4 Thu, 19 June 2003 04:48 Go to previous messageGo to next message
well done stu
happy boosting Smile
Classique71
Colac, Victoria
Re: Boost Gauge Installation - Gt4 Thu, 19 June 2003 08:42 Go to previous message
now i just have to figure out why the guage internals rattle at maximum boost - the noise is annoying - dinno if its a small leak or a fooked guage though it operates fine - or seems to
Previous Topic:difference between ma61 supra - and SA63/RA65 celica
Next Topic:where do i buy Clear plastic tubing 9mm?
Current Time: Fri Oct 23 03:01:53 UTC 2026
Total time taken to generate the page: 0.006181001663208 seconds
