Toymods » Tech & Conversions » flange 1j turbos onto 1g manifold?
japspec
icon3.gif  flange 1j turbos onto 1g manifold? Wed, 15 May 2002 11:25 Go to next message
Guys. Wondering what you think of having a flange made up to attach a set of 1jz turbos onto the manifold of a 1ggte motor. Ever seen it? Do you think it would be much cheaper than having a whole manifold made?
Cheers fellas.
japspec
Re: flange 1j turbos onto 1g manifold? Thu, 16 May 2002 08:31 Go to previous messageGo to next message
COME ON FELLAS!!!!!!!!!!
japspec
Re: flange 1j turbos onto 1g manifold? Thu, 16 May 2002 12:38 Go to previous messageGo to next message
Are you, talk'in ta Me!
Guest
Re: flange 1j turbos onto 1g manifold? Thu, 16 May 2002 22:10 Go to previous messageGo to next message
Do you mean an Adapter plate. I spose it could work
U sed an adapter plate for the vg30 on my old 3tgt. worked a treat and only cost me $80.
Darren
Re: flange 1j turbos onto 1g manifold? Thu, 16 May 2002 23:09 Go to previous messageGo to next message
Be brave, break new ground and TRY IT!!!
Darren.
japspec
Re: flange 1j turbos onto 1g manifold? Thu, 16 May 2002 23:11 Go to previous messageGo to next message
Yes! sounds good! I'll take two!!! Thanks mate!
I wonder if these impede the performance of the turbo.
Anybody know where I can pick up one of these babies.
Toyo3t: Where did you get yours mate?
Anymore thoughts before I go ahead and buy some turbos.
CT12's suck!!!! To quote an earlier post " all those pissy turbos are good for are ripping off and leaving on the ground to rust!"
Dam straight!!!!
Guest
Re: flange 1j turbos onto 1g manifold? Fri, 17 May 2002 01:42 Go to previous messageGo to next message
Adapter plates could be made by your exaust man.
Very simple concept, just a 10mm plate with countersunk bolts on one side. I even had mine machined so it didn't require gaskets.
I have been considering this kind of arrangement for my 1j.
twin rb20 turbo's or maybe something else.
You only neeed to sort out oil and water lines then.
I have heard of someone who put twin rb20's on his 1j but using a custom exhaust manifold, general concensus was that the 3-4000$ it ended up costing was not worth the gain. however with adapterplates instead of a $2000 manifold it may just be worth it.
I think he made nearly 350 rwhp. (limit of stocko's in <300.)
Something to think about
Pete
gold coast
Re: flange 1j turbos onto 1g manifold? Fri, 17 May 2002 01:45 Go to previous messageGo to next message
Don't play with CT12's or RB20 turbo's.
Put a T04e on there and be done with it.
You know you want to.
Guest
Re: flange 1j turbos onto 1g manifold? Fri, 17 May 2002 01:50 Go to previous messageGo to next message
OK you got me there...
I was just trying not to blow 6g's on a hair dryer setup.
and maybe preserve a little driveability...
Matt
Re: flange 1j turbos onto 1g manifold? Fri, 17 May 2002 02:29 Go to previous messageGo to next message
Pete check your PM's dude.
Took the head to the porter....like Big Kev says,"I'm excited!"
mx83toy
Re: flange 1j turbos onto 1g manifold? Fri, 17 May 2002 03:44 Go to previous messageGo to next message
just an idea...t78-34d????
Re: flange 1j turbos onto 1g manifold? Fri, 17 May 2002 03:59 Go to previous messageGo to next message
Nah-uh. U're missing the point...you dont want that.
If you're going to go that big..T88H34D anyone?
mx83toy
Re: flange 1j turbos onto 1g manifold? Fri, 17 May 2002 04:12 Go to previous messageGo to next message
lol yeah i know i was thinking of twin ct20's
i danno i'll probly keep it stocky
Guest
Re: flange 1j turbos onto 1g manifold? Fri, 17 May 2002 05:27 Go to previous message
Nah I 've already checked out the best turbo for my 1j, (within reason) If i was gunna buy a new unit on a budget I would get a garret t64. twin roller bearing, and just to the right of its efficiency band flowing 600 hp at 20 psi.
Previous Topic:Rubber Replacements for AE-86 ?
Next Topic:im definatly p
Current Time: Sat Nov 21 07:43:49 UTC 2026
Total time taken to generate the page: 0.0051121711730957 seconds
