Classifieds » Parts Wanted » need 22RE coil/ignitor (black 5pin TCCS type)!
jdro
icon2.gif  need 22RE coil/ignitor (black 5pin TCCS type)! Wed, 11 June 2003 11:26 Go to next message
I'm in Perth, searched high and low here at wreckers, none to be found...
i still have timing problems:
my current coil was original from carby setup, TCCS ignitor was from car i saw running before it was removed, spare computer both same, spare airflow meter both same, spare distributor/cap/rotor/leads all same, new injectors, checked wiring today and IGT/IGF/NE hooked up correctly, 12V to STA or NSW engages the circuit opening relay (and clears error code if lacking, separate fuel pump circuit I have so not relevant).
it will only run with fully advanced timing, and then it will be backfiring, flames from the exhaust, requiring ~20% throttle to "idle" ~1000rpm.
any suggestions welcome!
thanks,
David.
Assailant
"Cørønå ƒreåk"
Kellyville, Sydney
Re: need 22RE coil/ignitor (black 5pin TCCS type)! Fri, 13 June 2003 02:56 Go to previous messageGo to next message
I think I have one lying around at home
Assailant
"Cørønå ƒreåk"
Kellyville, Sydney
Re: need 22RE coil/ignitor (black 5pin TCCS type)! Fri, 13 June 2003 02:57 Go to previous message
I think I have one lying around at home, I have a pic as well
Previous Topic:AE86/Sprinter LSD
Next Topic:AE82 gearbox
Current Time: Thu Nov 19 06:20:17 UTC 2026
Total time taken to generate the page: 0.0056891441345215 seconds
