Toymods » Tech & Conversions » 1JZ - Missing under boost - Farts like gearshift...
thunderbird1
Sydney Australia
1JZ - Missing under boost - Farts like gearshift... Wed, 11 June 2003 18:31 Go to next message
Hey.. since dubbo i've had this hassle and i've tryed many things to fix it. TOnigth i pulled the fcd out so its not that.
It farts like it does on gear shift but it does it heaps when you come on boost... anyone else had this hassle?? i'd love to fix it.
DO u think it could be gearbox related??
I've done spark plugs... not that!
Luke
E30-323ti
Re: 1JZ - Missing under boost - Farts like gearshift... Wed, 11 June 2003 20:12 Go to previous messageGo to next message
My EVO did the same thing a while back.
It was one of the plug leads, the part that goes into the head had a tiny split in it and it was arcing to the head.
New leads fixed it.
I know the 1JZ doesn't have plug leads as such, but it could be a similar problem with the part from the coil to the plug.
Or one of the coils could be knackered!!
thunderbird1
Sydney Australia
Re: 1JZ - Missing under boost - Farts like gearshift... Thu, 12 June 2003 06:50 Go to previous messageGo to next message
cheers mate.. need to find someone with a spare set i can borrow for a day.
luke
celicamad
newcastle
Re: 1JZ - Missing under boost - Farts like gearshift... Thu, 12 June 2003 11:33 Go to previous messageGo to next message
hey luke . considering that the fart is the ecu pulling ignition out .then its likely E30-323ti is right .
i have a spare set of lead iginitor coils etc.Your welcome to try them . its possible a coil is breaking down ive heard of this happening before
email me or ring if you need them
mx83toy
Re: 1JZ - Missing under boost - Farts like gearshift... Sat, 14 June 2003 23:58 Go to previous messageGo to next message
freaky!!!!! mines doing the exact same thing dewd i've worked out its the box...it slips i tells the engine to back off (well misfires it so you dont stuff every thing up...i came to this conclusion when boosting in fourth at high speed....
Re: 1JZ - Missing under boost - Farts like gearshift... Sun, 15 June 2003 03:56 Go to previous messageGo to next message
I was wondering how long before luke toasted his gearbox Smile
EDIT: I've also got a spare set of coils, if epping is easier than newy
[Updated on: Sun, 15 June 2003 03:57]
thunderbird1
Sydney Australia
Re: 1JZ - Missing under boost - Farts like gearshift... Sun, 15 June 2003 13:03 Go to previous messageGo to next message
ahhh u could be right there. That would explain why it does it more under more boost and the motor revs perfectly until u power it up...
for example i can load it up to about 6-7 pounds doing maybe 5000-6000rpm.. but if u hit it hard, 10psi, fart fart fart.
Would also explain why sometimes it just goes damn hard and doesn't miss.. the box is getting grip.
DAMN IT! 2nd BOX !.. maybe its not dead. Just needs some tlc!
Soarer
Wollongong
Re: 1JZ - Missing under boost - Farts like gearshift... Mon, 16 June 2003 07:33 Go to previous messageGo to next message
... or an R154 conversion Wink
thunderbird1
Sydney Australia
Re: 1JZ - Missing under boost - Farts like gearshift... Mon, 16 June 2003 12:09 Go to previous message
nothing wrong with my BOX boys Wink .. filled it up with oil.. no more slippies... and guess what..
SHES FIXED!!!!!!!!!!!!!
was the coil packs.. now i gotta pay for the suckers Wink
Greg.. umm.. maybe i'll just take the whole engine for spare bits... Smile
Luke
Previous Topic:7M Ex-Manifold Flange (12mm) : Exp of Interest ??
Next Topic:Air Intake Length Long or Short?
Current Time: Fri Oct 23 23:06:42 UTC 2026
Total time taken to generate the page: 0.0048160552978516 seconds
