Toymods » Tech & Conversions » Stronger 4WD gearbox replacement for RAV4?
RAV-GT4
Toymods member
Rydalmere, NSW
Stronger 4WD gearbox replacement for RAV4? Thu, 27 June 2002 15:21 Go to next message
Hey guys...
Just mulling over the plans for my project, and I saw a thread on here that said something about a 4WD gearbox from another Toyota. Would I be able to drop in a stronger 4WD gearbox into the RAV4 if it's to succeed in it's ¼-mile destiny? Rolling If so, from what model, and roughly how much would the job cost?
Also, I heard on another forum that the RAV4 shares it's drivetrain heritage with the Celica GT-4. Can anyone confirm this? If it's true, I'll have no trouble with the quarter's! Grin
Cheers.
Darola
Taree, 4h nth of syd
Re: Stronger 4WD gearbox replacement for RAV4? Thu, 27 June 2002 15:52 Go to previous messageGo to next message
Hey there Bro, how r ya?? i know u can get a lsd box for the ravs, i will find out the price 2morrow, i'll also find out if the gt4 running gear is the same, i know its a big job to get a box out of a rav so im not sure how much they will charge, i remember a customer asking for it ages ago but never went ahead with it
Eddie (Darola)
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Stronger 4WD gearbox replacement for RAV4? Fri, 28 June 2002 02:58 Go to previous messageGo to next message
Thanks, appreciated Eddie. Also, bear in mind when you do find out which gearbox will replace the stocker, it's not like say a LandCruiser box with the normal 5-sp shift and the Hi-Lo on a stick next to it. The RAV has a normal 5-sp shift with constant 4WD.
Cheers.
Darola
Re: Stronger 4WD gearbox replacement for RAV4? Fri, 28 June 2002 07:17 Go to previous messageGo to next message
hey bigfella, yeah i know about the boxs, work on the cars everyday, joys of working at a toyota dealership
ok here goes, theres no lsd box for them only a lsd diff
the gt4 box will bolt on because its the same block and head but dont know how she will sit into the car or mounts line up.
hope this helps bro
Eddie (Darola)
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Stronger 4WD gearbox replacement for RAV4? Fri, 28 June 2002 14:02 Go to previous messageGo to next message
Sorry if I underestimated you mate, I didn't know you worked at Toyota... Smile
Don't the RAV4's have 2 diff's? Would they BOTH need to be LSD in that case? I'm not up on the workings of LSD diffs, only their by-product at the tyres... Grin
Any news on the GT-4 drivetrain similarities/heritage? Someone on the RAV4 forum (I think) told me that they have the same running gear, but I never got verification on this.
Ok, so if it's the same block and head (the block being the important part), hell I'm no mechanic but the gearbox setup comes with stick, gear-housing, gears, gear-mounts, bell-housing and what else? Should they mate up in theory?
Is there anyone else that would know for sure?
Cheers. Smile
[mikey]
Re: Stronger 4WD gearbox replacement for RAV4? Fri, 28 June 2002 14:53 Go to previous messageGo to next message
Rav4 has 3 differentials, front, centre and rear. The centre differential distributes torque split between front and rear diffs and the viscous coupling in the transfer case limits slip between front to rear. you only really need a rear LSD.... front requires the gearbox to come apart.
The gt4 box is of a similar setup and will fit on the motor, but most likely driveshaft ends wont fit into the box, tailshaft will be too long, mounts will be different for the transfer and x-member, etc. you wont know until you try, i am offering suggestions but i dont exactly know how it will fit, i have never fit one on a rav4, but its a beefier box than the rav4. but remember outer cv splines to hub are all the same from toyota so you can use gt4 driveshafts =]
michael.
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Stronger 4WD gearbox replacement for RAV4? Fri, 28 June 2002 15:00 Go to previous messageGo to next message
Thanks Mikey... ball-park figure on cost perhaps? If it's too much, I'll have to stick it on the back-burner for a while.
Thanks again.
[mikey]
Re: Stronger 4WD gearbox replacement for RAV4? Fri, 28 June 2002 15:15 Go to previous messageGo to next message
depends what importers are asking and if you can find one complete with shafts.....so sorry a ball figure i couldnt give u, give some importers a call....you may need a custom tailshaft which is close to $300-$400....but your going to have to redo whole drivetrain...if you strengthen one point, the next weakest part will take the load and break...if you find a GT4 tailshaft and rear diff / suspension cradle and rear shafts let me know please as i might be interested.
michael.
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Stronger 4WD gearbox replacement for RAV4? Fri, 28 June 2002 15:48 Go to previous messageGo to next message
Do you know of any importers in Northern NSW or SE Qld?
I wouldn't know who to contact.
Darola
Re: Stronger 4WD gearbox replacement for RAV4? Sat, 29 June 2002 01:26 Go to previous messageGo to next message
gidday , if your seriuus about the conversion then why dont you go the whole hog and fit the 3s-gte engine as well. they do fit in as it has been done. the st165 engine and gearbox is what the whole rav drivetrain is based on anyway so why not put the whole shebang in and start playing with wrx's with a relyable engine. the only problem is that the rear diff is sort of a one off unit and the celica diffs dont straight bolt up to the mounts , if you want i can talk to the guy that actually did the conversion and get some more info off him. i can also get the whole running gear package in for you if wanted , give me 3-4 days to confirm a definate price though.
GT4_Steve
Sutherland, Sydney
Re: Stronger 4WD gearbox replacement for RAV4? Sat, 29 June 2002 02:17 Go to previous messageGo to next message
Just so happens that I have a GT4 shell with full running gear (no, the engine I will keep;)
It comes with a GT4 gearbox that I am willing to seperate. The car has only done 29,000klms! I have has this car for about 3½ years now and salvaged various parts for my GT4's that I have owned.
Unfortunately, due to sumprik-stealing, It no longer has the seats and the dash and other interior type stuff has been sold to Moss.
I am willing to part with for $1500 and thats negotiable.
I also have a set of bilsteins (-1 front strut) and a set of King springs to suit any st185.
Maybe I should put a copy of this in the for sale section ! :)
[mikey]
Re: Stronger 4WD gearbox replacement for RAV4? Sat, 29 June 2002 14:54 Go to previous messageGo to next message
steve, is it a 185? i might be interested i nthe box for a decent price, we can discuss this later if you like..
in regards to that locked coupling, email me on slowae82@hotmail.com, other mail account is screwed at the moment...
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Stronger 4WD gearbox replacement for RAV4? Sat, 29 June 2002 15:40 Go to previous message
Hey Eddie - I'd be interested to find out whatever you can from your mate on the whole conversion process, what's involved and how much it's gonna run up. Thanks dude. Grin
Question - what kind of internals does the st165 engine run; I take it that's the 3S-GTE block/head setup? If it's a stronger standard setup than the RAV's 3S-FE donk's internals, I'd be keen to find out more about it and how much boost it can run up with a T-28 Garrett (the AVO kit) Wink
Cheers.
Previous Topic:1G-GTE timing
Next Topic:4AGZE water pump
Current Time: Tue Nov 3 07:46:43 UTC 2026
Total time taken to generate the page: 0.11730217933655 seconds
