Toymods » Tech & Conversions » Headlight High beam not working/
4AGE
Headlight High beam not working/ Thu, 12 June 2003 14:30 Go to next message
Hey just wondering... on my 86. When i put the headlights on it works... But when i flick the indicator forward for highbeam it turns off. How do i fix it. Is it in the headlight switch? or is it in the dashboard. Where could u recommend and who to take it to. Auto electrician or mechanic or whatever.... I"m in melbourne suggestions open. If any of u guy in melb willing to help fix it. I"ll pay u Shocked
ed_ma61
Lost in the K hole
Re: Headlight High beam not working/ Fri, 13 June 2003 00:16 Go to previous messageGo to next message
have you tried changing the bulb?
the low beam element is switched off when high beam is turned on, so if youve blown your high beam, itll just look like your lights turn off when you throw the switch forward.
just try the simple things first.
4AGE
Re: Headlight High beam not working/ Sat, 14 June 2003 03:51 Go to previous messageGo to next message
Hmmm i've changed bulbs... Worked fine for a month. On friday morning i checked them out n they worked again. And last night they didn't work... I'd really like to fix up this prob.
I usually drive around with highbeams on. I can't adjust my headlight to point forwards more either.. They basically point at teh ground almost.... not much projection.
Anyone can help meout?
P.S the screws on my headlights are stuffed... can't adjust them i think....
chrishanley
Re: Headlight High beam not working/ Sat, 14 June 2003 08:52 Go to previous messageGo to next message
this problem happens alot in the ae82 corollas which i'm pretty sure use the same high/low beam selector, its in the selector, so just walk down to your nearest wrecker and get a whole new blinker/wiper assembly, mine cost $25, then just take off your steering wheel and replace it, its really easy, I'd help you out with it but i'm in sydney, you can do it by yourself and all you need is a 14mm socket and a 1 point philips screwdriver, hope this helps
Chris...
ps. i assume that when you pull the h/beam thing it works but when you push to hold it on without assistance it turns all your lights off?
4AGE
Re: Headlight High beam not working/ Mon, 16 June 2003 07:19 Go to previous messageGo to next message
does the ae82 use the same steering column as 86?
24 crt panny
Barossa Valley
Re: Headlight High beam not working/ Wed, 03 December 2003 23:59 Go to previous messageGo to next message
I`ve got almost the same problem in my ke36 the lights switch off when i put high beams on but the high beam dash light comes on but.... when i pull the switch back to flash the beams on they come.
I`ve chect all wires and all i can think of is switch or head light can thinger u know like the flasher can only for the high/low beams. i`ve got new head lights and switch but havent instaled the switch of yet so i`ll have to get back to u once the mew switch is in.
Re: Headlight High beam not working/ Thu, 04 December 2003 06:51 Go to previous messageGo to next message
Have you looked for bad earths?
ae86drift
sydney.au
Re: Headlight High beam not working/ Thu, 04 December 2003 08:36 Go to previous messageGo to next message
Cool1 wrote on Thu, 04 December 2003 17:51
hehe
shane you are a big bad earth Wink
Brenton_TA23
Re: Headlight High beam not working/ Thu, 04 December 2003 10:34 Go to previous message
I had the same with my celica. I spoke to an efi guy i knew he said it is a common toyota thing, told me to swap the whole column swith and it fixed it perfect. It ended up being the connection between the wiper/headlight/indicator clip and the loom. A short fryed it. Maybe you could bypass it if that is the problem and if you cant find a the part.
Previous Topic:TA22 fuel line size
Next Topic:AE101 Speedo Help
Current Time: Fri Nov 20 09:23:16 UTC 2026
Total time taken to generate the page: 0.0054008960723877 seconds
