Toymods » Tech & Conversions » 2 piece tailshaft - TA22
Grega
melbourne.victoria.austra...
2 piece tailshaft - TA22 Thu, 12 June 2003 20:02 Go to next message
Was under the TA22 yesterday measuring the tailshaft length for my new custom - and found slap bang in the middle mounts for a centre bearing in the floor!
What TA22's came out with two piece shafts? Anyone know?
If anyone is interested 1355 is the length of my tail shaft from the back of the gearbox seal to the front of the diff.
Also the sprinter yoke uses some dodgy uni that is a press fit so getting that changed to a holden type using circlips - so its easily replacable.
Something else thats worth noting is the ae86 tailshaft I have and my manual TA22 shaft are exactly the same length (pity the centre bearing support is in a different place - otherwise it would have bolted up!)
[Updated on: Thu, 12 June 2003 20:03]
Re: 2 piece tailshaft - TA22 Thu, 12 June 2003 23:01 Go to previous messageGo to next message
Aus-spec TA22's never came with a 2-piece shaft, but I suspect the GT's did. Aus-spec RA23/28's were fitted with a 2-piece shaft.
thetoyman75
Club President
icon10.gif  Re: 2 piece tailshaft - TA22 Fri, 13 June 2003 00:07 Go to previous messageGo to next message
Norbie is spot on mate !
The JDM and Aus spec TA22 GT had a 2 piece tail shaft from factory. (Not sure about the american market. They were not really GT's they just had the trimming but none of the engine hardware so i dunno about there tailshafts. )
purpleminiep
Mentone
Re: 2 piece tailshaft - TA22 Fri, 13 June 2003 00:17 Go to previous messageGo to next message
Why are 2 piece tailshaft better? Are they better?
Brad
Re: 2 piece tailshaft - TA22 Fri, 13 June 2003 02:00 Go to previous messageGo to next message
Two-piece tailshafts are usually implemented to reduce drivetrain vibrations (ie they're easier to balance), and in a live-axle application like a Celica they have the added benefit of reducing unsprung mass.
juzzo84
Hornsby, N.S.W
Re: 2 piece tailshaft - TA22 Fri, 13 June 2003 15:48 Go to previous messageGo to next message
one of the ta22 that i used to own had a two piece shaft, and it was not a gt.
justin
tanman
Re: 2 piece tailshaft - TA22 Sat, 14 June 2003 11:09 Go to previous messageGo to next message
An RA23 two piece tailshaft is the same length as a TA22 one. I have measured them and am %100 sure. I actually fitted a one piece TA22 tailshaft to my old RA23 when the centre bearing failed. I see no reason at all why the RA23 2 piece shaft will not bolt into a TA22. The only modification needed is to change the yoke over.
I was under the impression that one piece tailshafts were stronger. Does anyone have any thoughts on this?
juzzo84
Hornsby, N.S.W
Re: 2 piece tailshaft - TA22 Sun, 15 June 2003 05:18 Go to previous messageGo to next message
yo tan man, im with you there, i thought that with the single piece that you would loose less power to the wheels, because there is one less join the power has to travel through to reach the wheels.
justin
IRA11Y
Club Member
Re: 2 piece tailshaft - TA22 Sun, 15 June 2003 06:41 Go to previous messageGo to next message
how many splines on the output shaft of the T50??
Re: 2 piece tailshaft - TA22 Sun, 15 June 2003 07:48 Go to previous messageGo to next message
Depends on what T50 you have.
IRA11Y
Club Member
Re: 2 piece tailshaft - TA22 Sun, 15 June 2003 10:20 Go to previous messageGo to next message
ok which one has the flat where the tooth is missing... 20 tooth? from memory?
thetoyman75
Club President
icon10.gif  Re: 2 piece tailshaft - TA22 Mon, 16 June 2003 00:22 Go to previous messageGo to next message
Micheal,
Its the sprinter that has that dodgy flat bit Razz
IRA11Y
Club Member
Re: 2 piece tailshaft - TA22 Mon, 16 June 2003 11:10 Go to previous message
hmm do T18's have that flat bit as well then?? cause ive got this gearbox and it has a celica bell housing but it fits a T18 tailshaft???
Previous Topic:Working out Gear Ratios
Next Topic:Turbo 4ac? 4atc??
Current Time: Tue Oct 20 23:53:13 UTC 2026
Total time taken to generate the page: 0.030699014663696 seconds
