Toymods » Tech & Conversions » HELP!! GZE s/c issues
Sprocket
The Central Coast
icon4.gif  HELP!! GZE s/c issues Fri, 13 June 2003 02:54 Go to next message
Hey peoples, I need your help.
Drove home at lunch time today, and noted that sometimes the supercharger wasn't kicking in until I squeezed the throttle a bit more.
Sometimes I can hear it's whine (cause the belt's not right, I'll fix that soon) then sometimes I can't hear it at all.
Obviously, it runs better when the s/c is actually running, but when it's not, a quick push on the throttle, and it snaps on with a squeek (belt slip) then pops off again.
I also thought it was weird that the damn thing started idling high, and whadayaknow, the damn s/c isn't turning off!
It happend last night too, the s/c just kept on spinning at idle for about 10mins, then pop, it stopped turning (clutch obviously disengaged)
But why the heck is it doing that? Any suggestions? Crying or Very Sad
xpimp
melbourne
Re: HELP!! GZE s/c issues Fri, 13 June 2003 04:54 Go to previous messageGo to next message
Hmmm cum to think about it mine does that sometimes Sad
Sprocket
The Central Coast
Re: HELP!! GZE s/c issues Fri, 13 June 2003 04:57 Go to previous messageGo to next message
Does your s/c keep running at idle too? Shocked
feral4mr2
Bundaberg, Qld.
Re: HELP!! GZE s/c issues Fri, 13 June 2003 05:45 Go to previous messageGo to next message
Freakthe s/c spinning all the time will not effect your idle.
the ABV is open at idle.
i had a fixed pulley on mine, and the idle was fine.
my old s/c which had the clutch would still spin it idle, but it wasnt engaged. it would look like it was, but it must of been a little drag on the clutch set-up?.
if i grabbed hold of the inner bit of the s/c pulley, it would stop spinning. and if i gave it a rev from the throttle body, i could see it engage and hear the small click.
the s/c is spose to be operated/engaged when the ECU picks up a certain level in your vacum (i'm not sure how vacum is measured, but noramlly when it got to -8 on my guage it would engage).
you can actually drive a gze with-out the s/c engaging if you dont apply much throttle.
Sprocket
The Central Coast
Re: HELP!! GZE s/c issues Fri, 13 June 2003 05:58 Go to previous messageGo to next message
Damn double post....grrrr
[Updated on: Sun, 15 June 2003 01:48]
Sprocket
The Central Coast
Re: HELP!! GZE s/c issues Fri, 13 June 2003 06:01 Go to previous messageGo to next message
Thanks Feral. Smile
Really? I can get to 0 vacuum without it engaging, then 'chirp' on it goes.
Sometimes it'll be on and I can hear it going and I'll get nice acceleration from down low.
When it's not on, it's like it's a twin cam all over again.
I wonder why it idles high sometimes Eye Spin
I can even hear it on when decelerating sometimes (it whines because of the belt) then other times it doesn't. Crying or Very Sad
Hmmmmmm.....
Time for an intake strip down and clean. Confused
sideshow
Re: HELP!! GZE s/c issues Fri, 13 June 2003 06:09 Go to previous messageGo to next message
check the relay for the super charger
ive wired up afew 4agze's and the relay has been full of water and it rusts up
the relay is triggered by the ecu and it earths the magnetic clutch on the super charger
Sprocket
The Central Coast
Re: HELP!! GZE s/c issues Fri, 13 June 2003 06:12 Go to previous messageGo to next message
Now that sounds like an idea! So ahh...where is it and what does this relay look like?
sideshow
Re: HELP!! GZE s/c issues Fri, 13 June 2003 07:05 Go to previous messageGo to next message
its above the gbox area
theres 2 types of relays
just hold it in yr hand while its plugged in and
free rev the engine quickly and it should click
if it doesnt pull the relay apart and see if its rusted
Sprocket
The Central Coast
Re: HELP!! GZE s/c issues Fri, 13 June 2003 07:07 Go to previous messageGo to next message
Will do! Thanks sideshow!
whiteGZE
Western Sydney
Re: HELP!! GZE s/c issues Sat, 14 June 2003 06:08 Go to previous messageGo to next message
With regards to your idle, do you have a front mount intercooler?
Front mounts are known to cause a lot of idle problems.
Sprocket
The Central Coast
Re: HELP!! GZE s/c issues Sun, 15 June 2003 01:51 Go to previous message
NOpe, doesn't have front mount intercooler. Std top mount.
Previous Topic:5SFE tranny gear ratios
Next Topic:Flutes air filters
Current Time: Sat Nov 21 04:31:43 UTC 2026
Total time taken to generate the page: 0.0049769878387451 seconds
