Toymods » General Car Talk » Fuel tank explosion risk?
Wattsie
icon5.gif  Fuel tank explosion risk? Fri, 13 June 2003 05:19 Go to next message
When I was wiring my lifting pump and installing into the RA28 tank, I thought "what would happen if the +12V connector somehow worked loose or fatigued and arced onto an earth"???
Is it true that if there was a spark that the A/F ratio would be so rich that ignition would not occur? I guess it's pretty variable how much O2 is in the fume fraction at any one time.
When a friend and I were modifying the fuel tank we rinsed the tank as best as possible and when it came to braising time, my mate waved the torch over the opening (I refused to be in the vicinity as I know the risks and how dodgy his method of de-fuming was) a whoosh and long yellow flames belched from all openings for a second or two (!!!).
Now, had there been more air in there and the vapors more oxygenated - BOOOOMMMMM. I think we were very lucky and my mate saw the error of his ways, almost fatally!
Fuel tank explosions/fires are bloody rare but a large passenger plane crash a few years back was attributed to wiring within an almost empty tank (of kerosene) arcing and blowing it outa the sky.
2 lessons: Properly degas tank before modifications + be sure your in tank pump is securely wired!
Jason
Re: Fuel tank explosion risk? Fri, 13 June 2003 06:55 Go to previous messageGo to next message
Yup personally seen a aircraft wing get blown up on the tar mac while someone was working on it because of stupidity. The other thing you can do is fill the tank up with an inhert gas of somesort so it displaces all o2 in the tank.
Re: Fuel tank explosion risk? Fri, 13 June 2003 07:53 Go to previous messageGo to next message
Something would have to go seriously wrong for that positive wire to come off(unless you did a bad job) for it to cause any problems. If it did come off and earth on the tank then I would say that there would be a very slim chance it would ignite. Of course if the tank was very empty and that wire earthed out above the fuel well then your fucked Shocked
juzzo84
Hornsby, N.S.W
Re: Fuel tank explosion risk? Fri, 13 June 2003 16:06 Go to previous messageGo to next message
shane you could not said it any more straight forward! Smile
Re: Fuel tank explosion risk? Sun, 15 June 2003 08:05 Go to previous message
The chances of ignition occuring inside a closed fuel tank are pretty much nil. Think of how your engine works: the fuel will only ignite if the mixtures are pretty close to 14:1 air/fuel, and even then it gets compressed to buggery before the spark does anything. Those conditions aren't likely to occur inside your fuel tank.
Previous Topic:Who Won the first ever Rice-a-thon????
Next Topic:what car?? help
Current Time: Thu Oct 29 15:21:08 UTC 2026
Total time taken to generate the page: 0.034271001815796 seconds
