Toymods » Tech & Conversions » Can i use the electronic Temp gauge with my new engine?
V8_MA61
Can i use the electronic Temp gauge with my new engine? Fri, 13 June 2003 11:07 Go to next message
Is it possible to use the temperature gauge from my ma61 supra with the v8 i have? It is a ford v8. Can i also use the same tacho or will i need a new one? If i can keep them...what things will i need to be able to use them?
[Updated on: Fri, 13 June 2003 13:00]
ed_ma61
Lost in the K hole
Re: Can i use the electronic Temp gauge with my new engine? Fri, 13 June 2003 13:06 Go to previous messageGo to next message
doh!
[Updated on: Fri, 13 June 2003 13:10]
V8_MA61
Re: Can i use the electronic Temp gauge with my new engine? Fri, 13 June 2003 13:17 Go to previous messageGo to next message
huh?
ed_ma61
Lost in the K hole
Re: Can i use the electronic Temp gauge with my new engine? Fri, 13 June 2003 13:19 Go to previous messageGo to next message
*misplaced post*
sorry - just ignore Smile
ed_ma61
Lost in the K hole
Re: Can i use the electronic Temp gauge with my new engine? Fri, 13 June 2003 13:26 Go to previous messageGo to next message
actually - just read the post Very Happy
if you can find a hole in the ford block (that communicates with a top end water gallery) with the correct thread to accept the temp sender from the original 5m-e just lob it in. if it doesnt fit however, adapters are available (maybe earls? - anyone). remeber, the 'correct' operating temps may differ slightly, so keep this in mind when reading the gauge.
as for the tacho - wont work - supra elec tach is calibrated for a 6cyl - not 8. may be a way to fudge somthing into the setup, but i doubt it. new tach required Smile
you get good answers when you ask reasonable questions huh Wink
ed
V8_MA61
Re: Can i use the electronic Temp gauge with my new engine? Fri, 13 June 2003 13:32 Go to previous messageGo to next message
yeah sorry that was a stupid question about the tacho...i remember now that the 6 and 8 are totally different... Embarassed
Will probably end up with a vdo one under the dash Smile
Ill have to have a look on the block about the temp thing...but if it all becomes too hard...i guess another vdo is the way!
All you people with the 7m/1j/2j and others - what have you done regarding the temp/ tacho situation?
Re: Can i use the electronic Temp gauge with my new engine? Fri, 13 June 2003 13:49 Go to previous messageGo to next message
Because the 7M/1J/2J engines are all 6 cylinders, the tacho signal will be accurate. However to actually make the tacho run, these guys run a black box that alters the signal in some magical way (I'm not electronically inclined). Our very own Grant (sixworks) sells these black boxes.
ed_ma61
Lost in the K hole
Re: Can i use the electronic Temp gauge with my new engine? Fri, 13 June 2003 13:52 Go to previous messageGo to next message
those black boxes are only to convert low voltage signals from individual coil packs to a signal analagous to that from a high voltag single dizzy/coil setup...
v8 is another wold of electronic dramas...
ed
V8_MA61
how about the temperature gauge setup? Surely it alters significantly between what is "normal" from the 5me to 7m/1j/2j???
Re: Can i use the electronic Temp gauge with my new engine? Fri, 13 June 2003 14:00 Go to previous messageGo to next message
Use the temp guage from your 5ME in your Ford V8. It is likely that you will need an adapter. The thermostat opens at 82 degrees for a 5ME so I suppose the operating temp is around that (a bit more - 85 to 90 I suppose). I have absolutely no idea what the operating temp of your Ford V8 is, but by using the 5M temp sensor, you can be sure it remains calibrated to the dash guage. You can then rest assured that the guage is accurate. However, the normal temp for your V8 may not necessarily line up with a normal temp for the 5ME.
1JZGTE and 2JZGE open at 82. Not sure of 2JZGTE or 7MGTE.
[Updated on: Fri, 13 June 2003 14:03]
V8_MA61
Re: Can i use the electronic Temp gauge with my new engine? Fri, 13 June 2003 14:11 Go to previous messageGo to next message
yeah i can imagine it wouldnt run quite as hot as the 5me...those poor old things did run pretty hot...I suppose its a trial and error thing...
[Updated on: Fri, 13 June 2003 14:12]
Re: Can i use the electronic Temp gauge with my new engine? Fri, 13 June 2003 14:17 Go to previous messageGo to next message
Personally, I'd plonk it all in and run it. Check the temp independently with a thermometer to make sure it isn't overheating.
V8_MA61
Re: Can i use the electronic Temp gauge with my new engine? Fri, 13 June 2003 14:19 Go to previous message
yeah thats what i had in mind Smile
Previous Topic:diff for hi powered sprinter?
Next Topic:Radiator Upgrade
Current Time: Fri Oct 30 15:50:51 UTC 2026
Total time taken to generate the page: 0.0057539939880371 seconds
