Toymods » Tech & Conversions » Air CON problems
limbi
Air CON problems Fri, 13 June 2003 17:20 Go to next message
hey guys i got an AE92 with a 20v motor. The only prob is that now my air con has totally knocked out. It doesn't even spin up when i startup the aircon. It was working fine about 1 month ago.... COuld it be a fuse?? any1 know where the fuse for the AC is kept? i haven't had any luck finding it. Any help would be appreciated
hydro
Re: Air CON problems Fri, 13 June 2003 18:42 Go to previous messageGo to next message
It could be a fuse, but it sounds like it's lost the gas out of it. Air-conditionering systems have 2 pressure switches, a high pressure and a low pressure switch. If there's not enough gas pressure to switch on the low pressure switch, the compressor won't spin up as you say.
If you can rule out a fuse, you might need to take it to a auto electrician or mechanic.
turbocamry
newcastle
Re: Air CON problems Mon, 16 June 2003 09:00 Go to previous message
yeah find the pressure switches and bridge them if it turns on than he is right it need gas
Previous Topic:Microtech MTX-8 with 4agze/te...
Next Topic:3tgte engines
Current Time: Sat Oct 17 13:36:21 UTC 2026
Total time taken to generate the page: 0.0051820278167725 seconds
