Toymods » Tech & Conversions » Working out Gear Ratios
ae86trueno
Working out Gear Ratios Sat, 14 June 2003 08:16 Go to next message
Ok ive pulled apart my T50 for a good clean and service, and was curious as to what the auctual ratios are, as i was told when i bought the car they were not standard, so how do i work it out ??
Help Appreciated
Ben
AE86 Trueno 4AGE
earlyrolla
Re: Working out Gear Ratios Sat, 14 June 2003 12:33 Go to previous messageGo to next message
Painstakingly count the number of teeth on each gear. For each set of meshing gears the ratio will be (output number of teeth / input number of teeth) which will give you some ratio as to one eg for first this maybe 3.2:1
For each gear (1st, 2nd, etc, except 4th) the drive will pass through multiple gear sets. To find the equivalent of a number of meshing gears, multiple the ratio of each set together.
Unless of course someone can identify the gear sets that are in there.
Have fun counting, Very Happy
IRA11Y
Club Member
Re: Working out Gear Ratios Sat, 14 June 2003 23:13 Go to previous messageGo to next message
some gear sets have stamps, you may have to give them a good wipe to find the stamp though
ae86trueno
Re: Working out Gear Ratios Sun, 15 June 2003 08:20 Go to previous messageGo to next message
Ok after some seraching i have got it worked out,(thanks to Bill's site)
my gearbox ratios are as follows
1st = 2.62
2nd = 1.891
3rd = 1.384
4th = 1:1
5th = 0.861
Which is the same as the TRD gearset Very Happy
Michael the only numbers on the gears are 22 92 which is on all the gears that i can see so im assuming that is batch number and build date
Ben
AE86 Trueno 4AGE
IRA11Y
Club Member
Re: Working out Gear Ratios Sun, 15 June 2003 09:55 Go to previous messageGo to next message
Pleased to hear the sets what its supposed to be Smile
I was going to say that i have a T50 allready semi split if you want to compare, but sounds like youve got it sorted Smile
ae86trueno
Re: Working out Gear Ratios Sun, 15 June 2003 22:41 Go to previous messageGo to next message
Is it just me or do some of the TRD Gears look semi helical??
http://us.f1.yahoofs.com/users/fdc6ad13/bc/My+Photos/gearbox.jpg?bcbhP7.ABVm1E89a
Ben
AE86 Trueno 4AGE
IRA11Y
Club Member
Re: Working out Gear Ratios Mon, 16 June 2003 11:13 Go to previous message
links not working for me
Previous Topic:Ins. Panel Gauge Bulbs Colour Change
Next Topic:2 piece tailshaft - TA22
Current Time: Thu Oct 22 11:56:36 UTC 2026
Total time taken to generate the page: 0.0051441192626953 seconds
