Toymods » Tech & Conversions » 40mm or 44mm solex
ta2272
40mm or 44mm solex Sat, 14 June 2003 11:30 Go to next message
how do i tell if my carbies are 40mm or 44mm.
Jonny2TG
Tasmania
Re: 40mm or 44mm solex Sat, 14 June 2003 12:12 Go to previous messageGo to next message
Measure the diameter of the throttle plates.
ta2272
Re: 40mm or 44mm solex Sat, 14 June 2003 12:19 Go to previous messageGo to next message
i was feeling in iside my carbs like i inch down the barrel there is like jets or something like were the fuel comes out of and cylinder 2 barell did not have one like the othere did is this meant to be like this. also the car isnt running great???
Jonny2TG
Tasmania
Re: 40mm or 44mm solex Sat, 14 June 2003 12:28 Go to previous messageGo to next message
You have to take the carbs off the engine to measure the throttles. Sounds like you are missing a few venturis. Oh well, if it runs then it runs. I expect it would not run so well at higher RPM, which means you can never have the max power your engine would otherwise make. Try and find the parts.
ta2272
Re: 40mm or 44mm solex Sat, 14 June 2003 12:43 Go to previous messageGo to next message
yeh the parts shouldnt be to hard to find should they couldnt i just order them from like repco.
Jonny2TG
Tasmania
Re: 40mm or 44mm solex Sat, 14 June 2003 12:51 Go to previous message
No. You need to get them second hand from a toymods person. They don't make solex sidedrafts anymore.
Previous Topic:Power Estimate
Next Topic:Rotary Valves
Current Time: Sat Nov 21 05:48:04 UTC 2026
Total time taken to generate the page: 0.043603897094727 seconds
