Toymods » Tech & Conversions » 3tgt distributor
roger
3tgt distributor Fri, 28 June 2002 02:20 Go to next message
Does anyone know how to pull the rotors off? or pull the distributor apart. I am having some difficultly. I undo the bolt on the rotor button but the thing won't come off?
Roger
Re: 3tgt distributor Fri, 28 June 2002 03:58 Go to previous messageGo to next message
A mate removed the weights from my 3tgte dizzy. Had to hacksaw as much of them off as possible then grind the rest. Didn't seem any easier way.
roger
Re: 3tgt distributor Fri, 28 June 2002 04:43 Go to previous messageGo to next message
turbo ra28,
Harsh move, he must have semi dismanteled the thing to be able to get at the weights though any ideas how he got at them?
Re: 3tgt distributor Fri, 28 June 2002 06:28 Go to previous message
Yeah we drilled out the pin through the gear, knocked the gear off.
Then was able to drive the whole shaft up out of the dizzy housing.
Hacked/grinded the weights off, welded the bottom and top half of the shaft together so it couldn't move around.
Put back into the housing and made up a new pin to hold the gear on.
Not sure if there is easier ways or not.. But this method did work. Assuming you never want to use the weights again!
Previous Topic:2TGEU Timing & Injectors
Next Topic:Conversion Kw to HP
Current Time: Thu Nov 19 19:09:17 UTC 2026
Total time taken to generate the page: 0.0063459873199463 seconds
