Classifieds » Parts Wanted » wtb: 1jz-gte twin turbo water pump
Chris Davey
sunny coast, qld
wtb: 1jz-gte twin turbo water pump Sat, 14 June 2003 13:55 Go to next message
anyone have a water pump as mine is leaking. It is connected to the power steering pump on the left hand side of the engine.
thanks in advance
chris
JAZE
cronulla
Re: wtb: 1jz-gte twin turbo water pump Sun, 15 June 2003 13:11 Go to previous messageGo to next message
actually its connected to the hyraualic fan drive, the p/steer pump is on the other side of the engine,i have one here you can have for 50 bucks, pm me and ill send you my number.
cheers.
Chris Davey
sunny coast, qld
Re: wtb: 1jz-gte twin turbo water pump Mon, 16 June 2003 12:37 Go to previous messageGo to next message
hi
i have my water pump off now so i will take a picture to see if yours is the same. My 1jz is out of a jzx90 chaser. what is yours out of? In mine, the power steering pump runs off the fan belt and we presumed that the water pump was running off the timing belt but it is actually on the same shaft as the power steering pump which is located directly infront of it. I should have a pic up by tomorrow night.
also, does anyone know if a 1g-gte water pump would fit?
chris
JAZE
cronulla
Re: wtb: 1jz-gte twin turbo water pump Mon, 16 June 2003 13:26 Go to previous messageGo to next message
dude, the serpentine belt runs:
water pump (which includes hydraulic pump for Fan)
altenator
p/steer pump
and a/c compressor
the one i have is a jzx90 water pump.
the p/steer pump is just under the intake manifold
Chris Davey
sunny coast, qld
Re: wtb: 1jz-gte twin turbo water pump Tue, 17 June 2003 09:59 Go to previous messageGo to next message
i am just trying to make sure that yours is the same as mine as i don't want to buy it and then find out that it does not fit. So...yours shouldn't have a pulley on the front of it then? mine has a flat part on the front which connects to some pump infront of it (not sure as some have been taken out that are not being used) and the pump infront has the pulley on it which is run by the front belt. Is yours the same as this? does it work? do you know how many kms? thanks
chris
JAZE
cronulla
Re: wtb: 1jz-gte twin turbo water pump Tue, 17 June 2003 13:14 Go to previous messageGo to next message
its a JZX90 water pump. i will put it in the garage and leave it there untill some one wants it. best of luck finding one anyway.
Chris Davey
sunny coast, qld
Re: wtb: 1jz-gte twin turbo water pump Wed, 18 June 2003 00:58 Go to previous messageGo to next message
so are you saying it doesn't have the flat front bit then? can't find the digi cam so haven't taken a photo yet. sorry.
Chris Davey
sunny coast, qld
icon4.gif  Re: wtb: 1jz-gte twin turbo water pump Thu, 19 June 2003 02:38 Go to previous message
ok i finally got a pic. it is the front section of the pump that connects to the pump infront of it. Can you tell me if yours has the same bolt pattern as this?
thanks in advance
chris
P.S does it work? Smile (just checking)
I will email you the pic
Previous Topic:Wanted: AE86 shocks, springs, suspension bits!
Next Topic:AE92 grill !
Current Time: Sun Nov 1 08:42:02 UTC 2026
Total time taken to generate the page: 0.050151824951172 seconds
