Toymods » Tech & Conversions » 2TGUE water pump and water temp sensor questions
bjkingwill
2TGUE water pump and water temp sensor questions Sun, 15 June 2003 05:57 Go to next message
hey guys i'm in need of advice.
First of all the water pump, i have a 2tgue but am in need of a water pump.
I have looked into buying a new water pump but have found that i can only get 2T water pumps which have an extra outlet which isnt needed on a 2tgue. Does anyone know where i could buy a new 2tgue water pump?
The reason i dont want to use a second hand one is because i've been told that the seals dry out when they arnt being used and then leak, is this true or have people found that a second hand pump will do?
I have also been told that i can use a 2t pump but need to cut off and block the extra pipe, is this a good suggestion?
I also need some advice with my water temp sensor. the sensor on my thermostat housing is broken a a new sensor is needed. i have found one off a 5ME which i have been told can be used. But i was wondering if they will differ in any way, such as resistance? the bolts which have the sensors in side them have the same number '89422-30020' on them but the 2tgue one also has '4 S' written on it but the 5ME one has '1 B'. Is this something to do with the sensors or with the bolts?
Any help or ideas would be very helpful!
Thanks guys
[Updated on: Sun, 15 June 2003 05:59]
inferno
Re: 2TGUE water pump and water temp sensor questions Sun, 15 June 2003 06:58 Go to previous messageGo to next message
For the water pumps, use the 2T pump and block off the extra connection. The 2TG pumps are rare, you'll probably have to buy a complete engine for one. I haven't heard of the seals going, but they get difficult to turn when they get old, might aswell buy a new 2T water pump, just make sure you use the right gasket so it won't leak.
The early efi was similar between engines, I imagine the resistor would be identical. It can't do much harm trying it. If you want to be certain just measure the resistances.
Goodluck
Re: 2TGUE water pump and water temp sensor questions Sun, 15 June 2003 08:12 Go to previous message
The sensor is almost certainly identical. The sensor in my 2JZ-GTE works the same as the old 5M-E, so it seems Toyota kept them the same.
Previous Topic:instrument conversion
Next Topic:Cold Air Induction
Current Time: Sat Nov 21 04:58:35 UTC 2026
Total time taken to generate the page: 0.018450021743774 seconds
