Toymods » Tech & Conversions » varying revs at idle
tomee
melbourne, australia
varying revs at idle Sun, 15 June 2003 09:42 Go to next message
hey guys
recently over the last few months i have noticed that my car varies revs at idle.
when slowing down to a stop the car will drop revs to about 600rpm and start to idle rough then jump back up to idle at around 800rpm. it idles jsut a tad rougher now.
it never used to do this. i dont have the AC on or anything else when it happens
could it be a dirty fuel filter?
car in question is a 96 camry V6
BansheeBuzz
Gold Coast
Re: varying revs at idle Sun, 15 June 2003 10:05 Go to previous messageGo to next message
this may sound silly but foot on or off the brake? any accessories on?
tomee
Re: varying revs at idle Sun, 15 June 2003 10:47 Go to previous messageGo to next message
no accessaries on, it happens when i come to a stop
so foot on brake.
BansheeBuzz
Gold Coast
Re: varying revs at idle Sun, 15 June 2003 10:49 Go to previous messageGo to next message
try it with you foot of the brake - reason is most toyotas efi systems are tied into the brake light switch and has been know to cause such symtoms as this b4
tomee
Re: varying revs at idle Sun, 15 June 2003 11:48 Go to previous messageGo to next message
but i wnat to get rid of it
it never used to do this...
BansheeBuzz
Gold Coast
Re: varying revs at idle Sun, 15 June 2003 11:51 Go to previous messageGo to next message
i realise that you want it make to norm. that is why i ask if it does it with the brake on and off, to eliminate the possibility of it being related to the brake light switch
tomee
Re: varying revs at idle Sun, 15 June 2003 12:47 Go to previous messageGo to next message
hehe yeah
ill try it out tommz
and ill get back to you on taht
turbocamry
newcastle
Re: varying revs at idle Sun, 15 June 2003 13:55 Go to previous messageGo to next message
sounds like it could be a vacume leak pour some water around the inlet mainifold around gaskets and injectors see if it stops or runs really bad if so u found the leak
dar_sbb
Re: varying revs at idle Sun, 15 June 2003 14:27 Go to previous messageGo to next message
In most cases it should be the brake booster. On idle does it miss? cause if it does check the plugs and leads.
tomee
Re: varying revs at idle Sun, 15 June 2003 23:18 Go to previous messageGo to next message
tested the brake method, it didnt really drop revs today
only ran just a tad rough on idle
cheked the plugs and they are clean as!
gotta test the inlet manifold for leaks latere this week...
new timing belt and mayb fuel filter installed also. see how that goes..
turbocamry: what camry have you got and is it really turbocharged???
turbocamry
newcastle
Re: varying revs at idle Mon, 16 June 2003 08:43 Go to previous messageGo to next message
its in a widebody camry 94 and i have put a 3SGTE motor in i have half a truck intercooler that i might put in if i keep it. man if ya fuel filter was blocked the revs wouldnt go up high it would stop u definatly have a vacum leak see if u can here a sucking noise around inlet manifold when u put ya head close or try the water works every time!
p.s u know anyone that would want to buy my car?
tomee
Re: varying revs at idle Mon, 16 June 2003 15:15 Go to previous message
nah not blocked, maybe jsut a dirty fuel filter...
have to test the inlet thing with water.. any got ideas on how i would do this? not sure how to
turbocarmy: sweet as! how much did the conversion cost? all up?
why not post your car on other forums such as performanceforums.com etc...
Previous Topic:Help! How much for a front spoiler?
Next Topic:Painting the block !
Current Time: Sun Oct 25 08:58:25 UTC 2026
Total time taken to generate the page: 0.020478963851929 seconds
