Toymods » Tech & Conversions » Speedo Problem
DiZ_
The Eastwood MASSIVE !
Speedo Problem Sun, 15 June 2003 15:18 Go to next message
I took the clear plastic cover off my cluster to give it a bit of a clean because it was getter very dirty. Upon doing so I accidently bumped my speedo needle below the zero mark and now it sits there below zero. The calibrating knob on the back raises the needle but soon as I stop turning it falls back down below zero.
Any ideas on how to fix it up.
ed_ma61
Lost in the K hole
Re: Speedo Problem Sun, 15 June 2003 16:06 Go to previous message
often, the needle indicator of a gauge is simply snugly press fitted over the steel pin of the potentiometer (ie the 'guts' of the gauge).
as such, the needle can be 'shoved' on its pin, and rotated into a new position when you try and rotate the needle beyond the range of movt of the 'guts' (which youve done).
to fix - you can either rotate the needle by hand in the opposite direction to the original shove, and wait for resitance to be felt, then push the needle further by the amount you want to reset it by.
alternatively, with fine pliars or a micro flat blade screwdriver, pull/pry the needle off the underlying shaft. then just put it back on at the zero point you want.
NOTE: this advice come from my pulling apart various OTHER kinds of gauges - not auto gauges. but im assuming theyre the same design.
ed
Previous Topic:celica/supra 5spd?
Next Topic:1ggte wiring looms
Current Time: Mon Nov 23 22:31:29 UTC 2026
Total time taken to generate the page: 0.0046939849853516 seconds
