Toymods » Tech & Conversions » ae82 dragging ass
86sprinter
sydney,greystanes
ae82 dragging ass Fri, 28 June 2002 06:52 Go to next message
hey guys
i recently lowered my ae82 onto a set of 16 by 7 inch rims with 205 40 series tyres. i well known tyre company in tempe (hint hint) did the deed using pedders springs (2 inches lower) now even after being assured that it would NOT scrub, well it does!!! anwyay after much talking with specialists and beig told many different things i am gonna replace the shocks. The wheels are rubbing inside the guard and i feel it is due to the pedders springs being softer then the other springs also the fact the the shocks are sitting two incehs lower then they should be.i need to be able to carry 4 people without to much hassle. the actual ride hight of the car isn't to bad as it can get in and out of car parks fine, it is just goeing around a corner or going over a bumb.
so i was wondering if anyone knew what sort of shock would fit an ae82 with two inch lower pedders springs and will it even help with the scrubbing. obviosuly the shock would have tobe reasonably hard. Also where abouts i could get them and what sort of money i would be looking at just for the shocks.
thanks guys any help would be much appreciated.
p.s
you may think why lower the thing so much in the first place well i was assuered that it would not rub i have seem a few rollas around here with 17s heaps lower then mine aslo a mate has a 89 rolla with ther same sized wheels and his is heaps lower, the back wheel has dissapeared under the gaurd and no rubbing so i thought.....
haggis
Re: ae82 dragging ass Mon, 01 July 2002 05:58 Go to previous messageGo to next message
I think you will find it has less to do with the shocks (yes, stiffer shocks will help, also shocks suited to the lower setup so the valving is right) as much as the springs, and the shape of the body work under the wheel arch.
If you look up in the rear wheel arch, there is only about 20mm between the lip that you see from outside the car, to an inner lip (its kinds hard to discribe, but obvious when you look at it) that prevents a wide wheel getting too far up indsie the arch.
Even a 185 section tyre does this (you get that when you try to carry 5 scuba tanks in a corolla sedans boot!)
What you would need to do is limit the point at which the suspension will let the wheel move up. Stiffer springs, different bump stops. This will alter the handleing, quite posibly adversly. Rolling the guard will give about that 20mm extra, but thats about it.
Craig.
Guest
Re: ae82 dragging ass Mon, 01 July 2002 07:31 Go to previous message
When was the last time you had it wormed ?
Previous Topic:Need Help with Rebuild
Next Topic:single carby for 2TGEU
Current Time: Wed Oct 28 18:20:52 UTC 2026
Total time taken to generate the page: 0.069844961166382 seconds
