Toymods » Tech & Conversions » rear drums to disc AE92
smithie
icon5.gif  rear drums to disc AE92 Fri, 28 June 2002 07:45 Go to next message
hi guys
I have a ae92 hatch cs with rear drums and i want to change to rear disc. If i get the rear struts, brakes and calipers off another ae92 sx or gti would they be a bolt on fit to my rolla? If not what would be the easiest conversion from drums to disc on my rolla? Does any other ae92 rolla beside sx or gti come with rear disc?
4RS_FED
Re: rear drums to disc AE92 Fri, 28 June 2002 11:28 Go to previous messageGo to next message
I'm pretty sure RV Corollas had rear disks as well.
Not sure about how easy it is to swap.
TCHOON
Sydney- Sutho Shire &...
Re: rear drums to disc AE92 Fri, 28 June 2002 11:45 Go to previous messageGo to next message
When I swapped the rear on my ae82, I kept my standard struts in there and just unbolted the 2 bolts holding the carrier on.
I did have to get the correct handbrake cables though. I am guessing the ae92 will be the same, but my guesses have been wrong before.. Rolling Eyes
Maybe the Ultima had discs all round ? , but not CS CSX in ae92 range.
[mikey]
Re: rear drums to disc AE92 Fri, 28 June 2002 15:18 Go to previous message
arms, carriers, handbrake cable setup, is all you need.....but your bias will be stuffed up if you dont change the master cyl/booster and proportion valve.
Previous Topic:RWD 4A-GZE Block only, Water Pump/Thermostat
Next Topic:3T head on a 2T engine?
Current Time: Thu Nov 19 14:11:34 UTC 2026
Total time taken to generate the page: 0.052659034729004 seconds
