Toymods » Tech & Conversions » 1G-GTE timing
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon8.gif  1G-GTE timing Fri, 28 June 2002 07:56 Go to next message
Hi guys,
Just playing with the timing of my car. When I short the TE1 and E1 pins in the diagnostics plug, the timing doesn't change. It was sitting on 35 and didn't move when the pins were shorted. I set the timing to 25 and drove around like that for a few weeks.
Then I did the timing again. Same thing this time too, shorting the pins didn't move the timing off 25... This time I set it to 10 degrees and it's running really badly.
The timing was done by different people with different equipment each of the times.
Is this a bit suspect?
Is there a current that goes across the pins? ie: Can I use a test light to check that I have the pins shorted?
My car is running like shit and it's pissing me off.
[mikey]
Re: 1G-GTE timing Fri, 28 June 2002 14:55 Go to previous messageGo to next message
max,
get your butt to my house and we will have a look at it. your lazy mate!
michael
Nark
Cabramatta, NSW
icon12.gif  Re: 1G-GTE timing Fri, 28 June 2002 15:32 Go to previous messageGo to next message
hehe It's too cold to go outside!!! Wink
I'll give you a shout if I see you online sometime this weekend. I really wanna figure this out before the dyno day. Disgusted
Dylo
Re: 1G-GTE timing Sat, 29 June 2002 03:28 Go to previous messageGo to next message
What does Earthing out the pins actually do for you Nark? is it really a good idea!!!!!?
And how do u time a modern engine engine like this? is it still to do with twisting the dizzy?
Nark
Cabramatta, NSW
icon2.gif  Re: 1G-GTE timing Sat, 29 June 2002 17:33 Go to previous message
Shorting out the pins sets the ECU into a special mode where you can do the timing. If the two pins aren't shorted, then the timing that it sits at during idle is different.... That's what I've been told at least... It's supposed to sit at 35 degrees advanced during idle... Connecting the TE1 and E1 pins together will set it to the correct timing so that you can change it.
And yeah, timing is done the same. Loosen the dizzy and twist.
Previous Topic:Toyota MTEU Turbo
Next Topic:Stronger 4WD gearbox replacement for RAV4?
Current Time: Tue Nov 3 06:55:07 UTC 2026
Total time taken to generate the page: 0.14029788970947 seconds
