Toymods » Tech & Conversions » Need for drive shaft problem of AE86
AE86JACK
Need for drive shaft problem of AE86 Mon, 16 June 2003 11:58 Go to next message
Hi, any one,
I had exchanged a LSD diff into my oz spec AE86, but my mechanic found that the input shaft of the new diff is longer than the original one, this make the drive shaft had to be put 6mm toward the gear box (but the car still run ok). Should such situation will cause any damage? should I exhange a drive shaft from another model?
Help really appreciated.
Jack
Sam
Sydney, Australia
Re: Need for drive shaft problem of AE86 Mon, 16 June 2003 19:52 Go to previous messageGo to next message
I've heard that a T18 driveshaft fits perfectly, but you'd wan't to measure it up first.
sam
IRA11Y
Club Member
Re: Need for drive shaft problem of AE86 Tue, 17 June 2003 09:32 Go to previous message
hes not quite using the same set up as me Sam, what you need to do is take the back half of the T18 tailshaft and mate it to the front half of the AE86 shaft and it should be the perfect length.... the T series diff housing is just that little bit longer Smile
Oh dont dorget to ballance the shaft after you put it all together Smile
Previous Topic:Boost Gauge Cup
Next Topic:what size wheel on ke30
Current Time: Sat Oct 24 00:20:52 UTC 2026
Total time taken to generate the page: 0.0048179626464844 seconds
