Toymods » Tech & Conversions » Need for drive shaft problem of AE86
AE86JACK
Need for drive shaft problem of AE86 Mon, 16 June 2003 11:59 Go to next message
Hi, any one,
I had exchanged a LSD diff into my oz spec AE86, but my mechanic found that the input shaft of the new diff is longer than the original one, this make the drive shaft had to be put 6mm toward the gear box (but the car still run ok). Should such situation will cause any damage? should I exhange a drive shaft from another model?
Help really appreciated.
Jack
fergo308
Eastern Sydney
Re: Need for drive shaft problem of AE86 Tue, 17 June 2003 13:03 Go to previous messageGo to next message
yes,the wrong tailshaft can cause you problems. when you go over bumps,you can damage the gearbox,as well as the shaft itself.
you're putting excessive loads on everything involved.
the length difference is more like 15mm btw,not 6.
either get the rear half of the tailshaft shortened by a specialist,or find an appropriate shaft from another toyota.
I've been told the T18 rear section is suitable.
Justin...
AE86JACK
Re: Need for drive shaft problem of AE86 Wed, 18 June 2003 01:54 Go to previous message
HI, everyone,
first say thanks to who give me the advice,
and could you tell a T18 tailshaft come from what car?
Regards.
Jack
Previous Topic:equations to calculate power and torque?
Next Topic:Who does HPC in canberra?
Current Time: Thu Oct 22 07:48:07 UTC 2026
Total time taken to generate the page: 0.0085849761962891 seconds
