Toymods » Tech & Conversions » 21R-C coil+ignitor for 18r-ge/22R-e electronic igntion - IT WORKS
21R-C coil+ignitor for 18r-ge/22R-e electronic igntion - IT WORKS Tue, 17 June 2003 03:05 Go to next message
ok guys, more stupid questions from me Very Happy
Well i have modified an 18R-C dizzy using 22R-E internals to make myself an electronic dizzy. Since i was unable to find a 22R-E coil+ignitor anywhere, i decided to try out a 21R-C coil+ignitor.
My questions are regarding the wiring. The old coil (with ext. resistor) had the BLACK/Red wires from the car going to the + of the coil, and the BLACK/Yellow wire from the car going to the resistor and then out of the resistor into the + of the coil.
THe solid black wire is pretty obvious...
So my question is this. What do i do with the Black/yellow wire? THis is the ignition wire from the car, and the Black/red from the car comes from the starter motor.
Here's a pic of the 21R-C coil+ignitor.
http://groups.msn.com/_Secure/0RADdApYTLYjKW5R5bINjMFZKrvgfKytfbPO1Y7BC*hml9D3CZZCohXnr53fCeN5MHC74UbWq134CczBG4tcrdfdqLVTd1aBbva4XyJFshKI/21R-C-coil.jpg?dc=4675426470297853010
The Black/Red wire pointed out is connected directly to the + of the coil, and the black wire next to it goes into the ignitor.
HOW DO I DO IT?
Thanks all Smile
[Updated on: Wed, 18 June 2003 02:03]
Re: Help using 21R-C coil+ignitor for electronic igntion. Tue, 17 June 2003 03:07 Go to previous messageGo to next message
Oh, and i have the wiring diagrams of the US 1977 celica (as seen on my desk) which shows a coil+ignitor which also uses an external resistor. (like the 5M-E style coil+ingitor)
I am confuzzled, since i have never played with electronic ignition at all....
BansheeBuzz
Gold Coast
Re: Help using 21R-C coil+ignitor for electronic igntion. Tue, 17 June 2003 08:09 Go to previous messageGo to next message
your black and red wire is ignition and the other one is your tacho output
BansheeBuzz
Gold Coast
Re: Help using 21R-C coil+ignitor for electronic igntion. Tue, 17 June 2003 08:11 Go to previous messageGo to next message
if the ignitor is not compatible with your 22r-e internals(dizzy) - i have a ciol/ignitor from a 22r-e.
You did use the leaded 22r-e dizzy didn't you?
Re: Help using 21R-C coil+ignitor for 18R electronic igntion. Tue, 17 June 2003 08:42 Go to previous messageGo to next message
dude - leaded, unleaded - i assume it would make little to no difference. The dizzy's i have available are from unknown RT-142's.
I have also since found out that i need to use the condenser with this coil+ignitor setup (which i did get thank god). I haven't bunged it in yet, but i might later tonite or fisrt thing tomorrow.
BansheeBuzz
Gold Coast
Re: Help using 21R-C coil+ignitor for 18R electronic igntion. Tue, 17 June 2003 08:44 Go to previous messageGo to next message
the difference is the unleaded 22re's used the tccs efi which had electronic spark timing (to vacume or mechanical advance)
Re: Help using 21R-C coil+ignitor for 18R electronic igntion. Tue, 17 June 2003 09:02 Go to previous messageGo to next message
no this one is definitely vacuum advance. It's the UBER cool dual diaphram vacuum advance too!
And yes of course it was from an analog EFI 22R-E. Very Happy
I just ripped out the magnetic pickup and star wheel, and bunged them into an old 18R-C points dizzy.
In any case.. i will find out soon enough if it works Very Happy
Re: 21R-C coil+ignitor for 18R electronic igntion - IT WORKS Wed, 18 June 2003 01:29 Go to previous messageGo to next message
IT WORKS!
tried, tested, and fully operational.
Indeed the black/red wire goes to the black/yellow wire from the RA28 (which is ignition), and the black goes to the black on the RA28 (tacho).
AS WELL AS THIS! a condenser is required from the 21R-C also. These are a 2 wire semiconductor looking device that is usually bolted down on one of the mounting tabs of the coil. It goes between the ignition feed to the coil and earth.
And my word has it made an improvement. I can happily rev above 6000rpm now!
Re: 21R-C coil+ignitor for 18R electronic igntion - IT WORKS Wed, 18 June 2003 02:03 Go to previous messageGo to next message
How important is that condensor? I recently wired up a 5me and didn't add this, just figured it might stop some electrical noise in the radio etc.. But is there more to it than that??
BansheeBuzz
Gold Coast
Re: 21R-C coil+ignitor for 18R electronic igntion - IT WORKS Wed, 18 June 2003 08:52 Go to previous messageGo to next message
basically thats all it is for on an electronic system. It is very important to have a condensor on a points system thou.
Re: 21R-C coil+ignitor for 18r-ge/22R-e electronic igntion - IT WORKS Wed, 18 June 2003 11:38 Go to previous messageGo to next message
if you have points and no condensor - bye bye points!! Shocked
You get MEGA voltage builtup on the points and they arc out.
I figured i wanted the condensor because i HATE engine noise in my stereo Mad
BansheeBuzz
Gold Coast
Re: 21R-C coil+ignitor for 18r-ge/22R-e electronic igntion - IT WORKS Wed, 18 June 2003 11:44 Go to previous messageGo to next message
glad you got it working. Was the dizzy internals easy to swap?
Re: 21R-C coil+ignitor for 18r-ge/22R-e electronic igntion - IT WORKS Wed, 18 June 2003 12:39 Go to previous message
dude - i couldn't have been ANY EASIER!
it was all screw out and unclip - then screw in and clip in! SO SIMPLE! Everything fits perfectly from the RT-142 corona!
Previous Topic:electronic ignition for 2tg
Next Topic:RA29 GT front spoiler information
Current Time: Fri Oct 16 12:03:15 UTC 2026
Total time taken to generate the page: 0.0059530735015869 seconds
