Toymods » Tech & Conversions » weird dyno readings (help)
takai
icon5.gif  weird dyno readings (help) Tue, 17 June 2003 14:25 Go to next message
Heya all
As the first thread which im starting in this forum i thought i would pose a little problem.
I had this dyno done yesterday
http://www.dysfunction.ws/albums/CorollaSX/dyno1606.gif
Now what im wondering is what the little flatspots on the graph are. They are too small to be gear changes, so thats ruled out.
There was also a note on my reciept which said: "NOTE: Number 1 lead is open circuit" which has stumped me. Ive tried disconnecting the number one lead and the idle definately changes.
I dont think im getting pre-detonation on Cyl1 because i cant hear anything abnormal. I hope im not anyway.
Help?
BansheeBuzz
Gold Coast
Re: weird dyno readings (help) Tue, 17 June 2003 21:09 Go to previous messageGo to next message
leads can appear fine under no load but breakdown under load.
As for that dyno chart. There should be no gear changes in that.
It should be done in 4th gear(or which ever gear is 1:1). I have never seen a dyno chart that does not have some sort of dip or low in it before. I would not be concerned about this.
EMP-2TG
Carlingford, Sydney
Re: weird dyno readings (help) Wed, 18 June 2003 00:04 Go to previous messageGo to next message
that wasnt done in 4th
Nark
Cabramatta, NSW
      Nark@toymods.net/Work
icon3.gif  Re: weird dyno readings (help) Wed, 18 June 2003 00:10 Go to previous messageGo to next message
Topping out at 120km/h suggests it was done in 3rd gear.
Try borrowing a set of leads and sticking them on. See if you notice a difference.
Re: weird dyno readings (help) Wed, 18 June 2003 00:18 Go to previous messageGo to next message
That's a third gear run. The clues are the 2000 Nm of torque (Rolling Eyes) suggesting rather a lot of multiplication and the peak speed of ~120 kph. Other than that, the curve looks otherwise normal.
Why should the note on your receipt have you stumped? Didn't you pay good money to have the dyno done? Why not have a chat to the dyno guy and ask him to explain to you what he meant by that.
takai
Re: weird dyno readings (help) Wed, 18 June 2003 00:26 Go to previous messageGo to next message
I should have made the note that that run was only to 6400rpm. But from the little test i did today it seems to be a 3rd gear run.
Probably because i dont think this gearbox has a 1:1 ratio gear.
The guy who did the test is currently sick and not at work unfortunately. Otherwise i would probably have a better understanding. Also none of the rest of the guys there can figure it out because they agree that there is still spark going to the number one cylinder.
Also i have seen graphs which have no dips or notches in them, and the possible ignition issue is worrying me slightly. The issue was pointed out by someone on another forums without them seeing the note on the reciept, which suggests to me that maybe there might be something in it.
Anyone else got a clue for me?
Re: weird dyno readings (help) Wed, 18 June 2003 01:28 Go to previous messageGo to next message
only an engine brand new from the factory will have no flatspots, and even then it may have some.
basically, the smoother the graph, the smoother your power delivery.
thetoyman75
Club President
icon5.gif  Re: weird dyno readings (help) Wed, 18 June 2003 02:11 Go to previous messageGo to next message
I am no expert but a curve like that would indicate to me your power delivery is deffinatly less than Ideal. Bad spark caused by a dodgy lead could be a part of it and the dyno tunner would not have writen it if it were not an issue.
You may simply have some spark escaping or earthing out under load. This will result in a less than ideal burn when that cylinder fires. Lead s are not necessarily dead or alive. There is alot of in between
Don't read too much into dynos - what does the car actually feel like? Wed, 18 June 2003 02:54 Go to previous messageGo to next message
The gradient of that power curve will be an index of acceleration. The slightly bumpy nature suggests variable acceleration at full load. This would feel like the car is stuttering all the way thru acceleration.
During a flat throttle acceleration run does your car stutter all the way thru the rev range? If so, you have a problem that needs sorting. If not, ignore the 'bumps'. They are very common when using a chassis dyno.
[Updated on: Wed, 18 June 2003 02:55]
GIN51E
Berowra-Sydney
Re: Don't read too much into dynos - what does the car actually feel like? Wed, 18 June 2003 08:11 Go to previous message
I would consider this a more normal power curve and thats out of an engine 20 odd years old,
http://www.planet.net.au/~gins/dyno.jpg
yours has problems no way the power curve should move around so much you must have some sort of ignition problem to make your graph move around so much,
i suggest you go out and buy some new leads its not expensive and the lead doesn't have to be earthing to be classed as faulty if the resistence in them is too high then that will effect engine performance as well, get new leads and try again,
and i'm sure your car has a 1:1 ratio, only reason it wouldn't is if you have changed all your gear ratio's???
Previous Topic:GT Front Spoiler
Next Topic:fuel tanks
Current Time: Wed Oct 14 18:47:24 UTC 2026
Total time taken to generate the page: 0.10567617416382 seconds
