Toymods » Tech & Conversions » Million dollar question
JonsonRA23
Hobart, TAS
Million dollar question Sat, 29 June 2002 00:14 Go to next message
I just replaced the carby on my 18r motor coz i thought the accelator pump/squirter thing was stuffed, i still have the problem in that when i try to accelerate from down low (1000-3000rpm) in like 2/3/4th gear the motor spits/coughs once or twice then goes, and lately its started to bang/pop when revin around 4000rpm. Its real bad when the motors cold, the choke is disfuntional but its not that coz it still does it when the motor is hot, ive checked for air leaks and the timings right.
Any ideas, if u fix it i will send you one million dollars.
I just need it to go ok for a few more weeks till i get my 18rg.
[Updated on: Sat, 29 June 2002 00:17]
Re: Million dollar question Sat, 29 June 2002 00:46 Go to previous messageGo to next message
Manifold leak between intake and exhaust? Generally this is the culprit for shit running 18R's.
You better send me that million........
JonsonRA23
Hobart, TAS
Re: Million dollar question Sat, 29 June 2002 04:51 Go to previous messageGo to next message
I put in a new gasket the other day so there shouldnt be any leaks there, you should phone a friend and try again.
Apollo
Brisbane, QLD, Australia
Re: Million dollar question Sat, 29 June 2002 10:43 Go to previous messageGo to next message
Check your fuel lines and filter. Check what condition the plugs are in too.
Could be a vaccum leak. Tighten that carby on more. But the gasket replaced was what? Just for the carby, or for the intake onto the head? (Which I think GT was getting at).
Celica_RA40
Re: Million dollar question Sat, 29 June 2002 13:14 Go to previous messageGo to next message
sounds like idle mixtures to me. an old carby has prolly worn out and you will never be abel to set the mixtures properly. carby rebuild or put up with it till the 18R- goes in
Allan
Re: Million dollar question Sat, 29 June 2002 13:57 Go to previous messageGo to next message
the secondary barrel maybe opening too soon, get someone to follow you see if it blows black smoke.
Allan
Jonny2TG
Tasmania
Re: Million dollar question Sat, 29 June 2002 14:36 Go to previous messageGo to next message
If you bring it around on monday, I will go for a drive and see what it is. And we will check ignition timing and stuff as well. But as others say, its probably a air leak of some sort.
Re: Million dollar question Sat, 29 June 2002 18:13 Go to previous messageGo to next message
Face it, he ain't got a million to pay up anyway Grin
Jofus
Re: Million dollar question Sat, 29 June 2002 23:23 Go to previous messageGo to next message
If he actually did have 1 million, he wouldn't have an 18R.........
JonsonRA23
Hobart, TAS
Re: Million dollar question Sun, 30 June 2002 04:24 Go to previous messageGo to next message
Ive had it with this shit motor, the point gap looked to small so i set it right and now the motor wont even start.
Stuff it, i will use my girlfriends and mums cars till i get the 18rg.
suprav8
melbourne
Re: Million dollar question Sun, 30 June 2002 10:32 Go to previous message
sounds like a points problem for sure....get some new points ,set the gap correctly and she`ll run like a dream
Previous Topic:Can you believe this 1JZ?
Next Topic:Engine Info
Current Time: Sat Oct 31 14:21:21 UTC 2026
Total time taken to generate the page: 0.1362669467926 seconds
