Toymods » Tech & Conversions » electronic ignition for 2tg
nobbatron
perth
electronic ignition for 2tg Wed, 18 June 2003 08:24 Go to next message
ok, so i got a suitable dizzy and coil+ignitor from an efi 2tgeu for my carbied 2tg, connected it up, and couldn't get any spark at all. the ignitor has two wires running to the coil, two to the dizzy and one extra wire which doesn't seem to have a place to go. have i got the wires wrong or something? has anyone got a wiring diagram for this set-up, or done this before? any ideas anyone?
inferno
Re: electronic ignition for 2tg Wed, 18 June 2003 10:24 Go to previous messageGo to next message
Someone had the same sort of problems with the 22RE coil, I went through how my 22RE coil was wired about half way down the page, this may help you as the colour wires should be similar-
http://forums.toymods.org.au/index.php?t=msg&t h=9563&prevloaded=1&rid=100&S=13d0ed23 2fd0d344688375f6f2d9843b&rev=&reveal=& start=20&count=20
the only thing i can suggest is to make sure the coil has power(+ive), the ignitor is getting a strong signal from the distributer and the ignitor is wired the correct way to the coil. Has the coil been tested?
Goodluck
rob
Re: electronic ignition for 2tg Wed, 18 June 2003 11:33 Go to previous messageGo to next message
is it a 4 wire or 5 wire ignitor? (dunno if a 4 wire exists..)
i just recently modified my 18R-G points dizzy with 22R-E electronic dizzy internals and used a 21R-C coil+ignitor, and got it working 110%.
There should be only two wires you have to connect to the car itself - that being the Ignition (12V+) wire and tacho wire.
From the ignitor, i had these 5 wires:
- one going to the (-) terminal of the coil
- one going to the (+) of the coil, which is also where ignition from the car is connected
- One going to the tacho wire from the car
- and two going to the electronic dizzy.
I hope this helps. I don't know if the 2T-GEU electronic ignition runs the same as what i used......
juzzo84
Hornsby, N.S.W
Re: electronic ignition for 2tg Wed, 18 June 2003 13:42 Go to previous message
if you need a wiring diagram i have a few 2tgeu ones that i can send your way, just lemme know
justin
Previous Topic:where to find an ae101 levin 20v o2 sensor (or other brand that will work good)
Next Topic:21R-C coil+ignitor for 18r-ge/22R-e electronic igntion - IT WORKS
Current Time: Mon Oct 19 15:50:07 UTC 2026
Total time taken to generate the page: 0.0037181377410889 seconds
