Toymods » Tech & Conversions » 2T problems
silverfox
Cabooture QLD
2T problems Wed, 18 June 2003 08:36 Go to next message
ok , me and a friend finished putting my 2T back together today and we run into the problem of when i cranked it over , it was pushing oil out of between the block and the head only at the front of the engine the head has been torqued down rite and new gaskets etc..
is my head warped ? and can it still be shaved down and still used
earlyrolla
Re: 2T problems Thu, 19 June 2003 04:55 Go to previous messageGo to next message
It will only push out oil at the front of the head coz that is where the high pressure oil feed passage is.
If the gasket was new and both surfaces (head an block) were cleaned properly then it would probably be a warped head.
Have to pull it off and check it with a straight edge and feeler gauges, or get a head shop to do it for you.
A cylinder head can be shaved and still be reusable. The amount shaved off the head before the head is stuffed, depends on the manufacturers specs. I know 18RG is only 40 thou.
Note that once you shave the head, it then increases compression slightly and will put more strain on the bottom end.
Re: 2T problems Thu, 19 June 2003 05:13 Go to previous messageGo to next message
it sound slike ther eis something mechanically interfereing with the head seating on the block. if the dowels are too long or not properly aligned, you can still torque it up, but it doesn't even begin to seal..
pull the head off, check the gasket carefully to see if it has been compressed at the metal ring at the oil feed hole. if not, there was no pressure on it.
with no gasket, check that the head sits neatly onto the block, if it doesn't touch the block, then the gasket will not be compressed.
check your head bolts are not bottoming out...
check both the block and the head for straightness, a small amount of warpage can be taken up by the gaskets, but too much and a slight shave will be needed. if in doubt take it to a reputable head shop to have it checked. i recommend Sydney Clutch and Brake near botany rd, alexandria...
good luck,
oh right.. brisbane Wink sorry, shoulda checked first.
silverfox
Cabooture QLD
Re: 2T problems Thu, 19 June 2003 06:46 Go to previous messageGo to next message
well tomorrow its gonna be taken to the shop and i'm gonna have it shaved down a little that should fix it i hope
thanks for the advice
Anyone know if its possible put a EFI system on a 2T and how , and what would i need to do this?
inferno
Re: 2T problems Thu, 19 June 2003 08:35 Go to previous messageGo to next message
you need a 3T-EU EFI manifold. These are very rare!! apart from that, either aftermarket computer or some sort of early toyota computer will do, loom, efi fuel pump, possibly electronic ignition, water temp sensor, possibly air flow meter, accelerator cable.
If your 2T is worked you would most likely need an aftermarket computer. IMHO some cheap downdraught webbers or the twin carbies off a 2T-B would be an easier and cheaper alternative.
silverfox
Cabooture QLD
Re: 2T problems Thu, 19 June 2003 08:53 Go to previous messageGo to next message
thanks , i was just wondering how hard it would be , was thinking of making a Turbo Efi 2T .
will all 3T manifolds fit a 2T ?
Grega
melbourne.victoria.austra...
Re: 2T problems Fri, 20 June 2003 02:49 Go to previous messageGo to next message
yes the 3TEU manifold does fit the 2T
http://www.vncommodore.com/images/celica/CelicaEngine003.jpg
silverfox
Cabooture QLD
Re: 2T problems Fri, 20 June 2003 03:20 Go to previous message
damn Grega that looks nice
Previous Topic:Ignition timing on 18RGU
Next Topic:ae86 - wheel offset question
Current Time: Thu Nov 19 19:25:49 UTC 2026
Total time taken to generate the page: 0.0074419975280762 seconds
