Toymods » Tech & Conversions » do toyota make an alloy block engine besides the 1 UZ?
JAZE
cronulla
do toyota make an alloy block engine besides the 1 UZ? Wed, 18 June 2003 15:00 Go to next message
wondering if there are any toyota alloy block engines perhaps v6?
or does anyone know of any good small all alloy engines from another manufacturer?
Re: do toyota make an alloy block engine besides the 1 UZ? Wed, 18 June 2003 15:05 Go to previous messageGo to next message
Toyota make a few all alloy blocks, I'm assuming you mean something with a little bit of size as you suggested the V6 and 1UZFE.
Excluding the mucho-$ 1GZFE, the next cheapest would probably be the 3UZFE. For the extra price it wouldn't be worth it atm over a 1UZFE. The Toyota V6's aren't known for their strength really, and their other engines are smaller.
There are always the Nissan VQ series of V6's, the new ones like in the 350Z. They also make the VH (?) series of 4.1l V8 and 4.5l V8, but from most accounts these aren't built to the same standard as a 1UZFE....actually, not much is Razz
Re: do toyota make an alloy block engine besides the 1 UZ? Wed, 18 June 2003 23:03 Go to previous messageGo to next message
Also the V series V8s. All alloy, OHV V8 (like a small Hemi V8). 2.6 thru to 3.9 litre capacity.
biased99
Re: do toyota make an alloy block engine besides the 1 UZ? Wed, 18 June 2003 23:35 Go to previous messageGo to next message
justcallmefrank wrote on Thu, 19 June 2003 01:05
I think the Nissan V8s powering the Infiniti are actually termed VG45DE...The early ones are simply not worth it, as the engine runs a timing chain with a plastic Shocked timing chain tensioner which, on higher mileage units, has been known to let go, with predictably catastrophic results...
Like all OHV engines, they aren't really worth it without throwing major $$ at them. For example, I think the 3.9lt's power output stock is around 125KW...
Kman
Re: do toyota make an alloy block engine besides the 1 UZ? Wed, 18 June 2003 23:45 Go to previous messageGo to next message
isn't the 1JZ an all alloy block?
biased99
Re: do toyota make an alloy block engine besides the 1 UZ? Wed, 18 June 2003 23:55 Go to previous messageGo to next message
Kman wrote on Thu, 19 June 2003 09:45
No.
Cast iron block/alloy head.
Re: do toyota make an alloy block engine besides the 1 UZ? Thu, 19 June 2003 00:19 Go to previous messageGo to next message
The ZZ series engines are also all alloy.
Biased99: Nissan's V8 is actually the VH series (eg VH45DE). The VG series is the V6 (as used in the 300ZX for example).
Re: do toyota make an alloy block engine besides the 1 UZ? Thu, 19 June 2003 00:23 Go to previous messageGo to next message
Nissan SR16/20 engines are all alloy.
Other Nissan alloy donks. http://www.freshalloy.com/site/features/tech/engin es/home.shtml
[Updated on: Thu, 19 June 2003 00:26]
Re: do toyota make an alloy block engine besides the 1 UZ? Thu, 19 June 2003 00:26 Go to previous messageGo to next message
Woohoo! How can I remember so much useless crap about engine models, and specs, yet not put this memory to good use with uni stuff?
biased99
Re: do toyota make an alloy block engine besides the 1 UZ? Thu, 19 June 2003 00:29 Go to previous messageGo to next message
Norbie wrote on Thu, 19 June 2003 10:19
Whoops... Embarassed (Still the rest of the point re: timing chains et al is valid...)
Which engines are the VQ-series, then?
Re: do toyota make an alloy block engine besides the 1 UZ? Thu, 19 June 2003 00:30 Go to previous messageGo to next message
VQ series is the new line of all-alloy V6's, used in the 350Z, the Maxima and the Skylines.
Oh, and the JGTC Skylines run a VQ30DET(T?) Smile
Chris Davey
sunny coast, qld
Re: do toyota make an alloy block engine besides the 1 UZ? Thu, 19 June 2003 01:07 Go to previous messageGo to next message
my mate has a VQ30Det in his laurel. they have around 195kw standard but he has upgraded the turbo to an sti one, wolf 3d (barely tuned), exhaust and FMIC. It is pretty good, but i much prefer the smoothness of the straight 6 like my 1jz. It doesn't seem to make as much power but the boost comes on very early for a single turbo. it also has a timing chain not a belt.
later
chris
Soarer
Wollongong
Re: do toyota make an alloy block engine besides the 1 UZ? Thu, 19 June 2003 02:32 Go to previous messageGo to next message
The 1MZ-FE from the V6 Camry uses an alloy block. It was one of the very few improvements over the 3VZ-FE it replaced.
FWDCelica
sydney,nsw.oz.
icon14.gif  Re: do toyota make an alloy block engine besides the 1 UZ? Thu, 19 June 2003 07:09 Go to previous messageGo to next message
Hey,
Soarer is right! 1MZ-FE is all Alloy 3 Litre V6 (Front Wheel Drive). They can be had with Manual or Auto.
A variation also comes in the Lexus ES300 now with VVT. (158KW/300Nm)
Very Smooth !!
T.
JAZE
cronulla
Re: do toyota make an alloy block engine besides the 1 UZ? Thu, 19 June 2003 14:50 Go to previous messageGo to next message
is the es300 RWD?
i wana use a 1MZ for a RWD conversion
Re: do toyota make an alloy block engine besides the 1 UZ? Thu, 19 June 2003 15:39 Go to previous messageGo to next message
Nope, ES300 aka. SuperCamry is FWD. Toyota havent made a RWD V6 yet I don't think.
Re: do toyota make an alloy block engine besides the 1 UZ? Thu, 19 June 2003 23:00 Go to previous messageGo to next message
They have (Hilux), but not in a passenger car to my knowledge.
1UZ FTE
Re: do toyota make an alloy block engine besides the 1 UZ? Thu, 19 June 2003 23:02 Go to previous messageGo to next message
Guys
If anybody has any Tech information/model details on the 1MZ-FE i would be very interested so far all i found out is a few power quotes and the weight of the motor ,.which is 151kg apparently
What cars do they come in and which ones are manual and Auto variations gear ratio's etc
or even a good link to them would be great
Does anybody know of a wrecker/importer with one,.so far i have come across one a couple of months ago and it was already sold
jamie
chrisss
melb
Re: do toyota make an alloy block engine besides the 1 UZ? Fri, 20 June 2003 07:14 Go to previous messageGo to next message
whats going on? are people finally getting interested in putting good sized motors (like a V6) into their cars?
whens someone gunna actually do it!!
Re: do toyota make an alloy block engine besides the 1 UZ? Fri, 20 June 2003 07:26 Go to previous messageGo to next message
I think the main reason is they never came in a RWD car, not even any of the RWD Hiluxes have them either, only the 4WD versions.
macks
Re: do toyota make an alloy block engine besides the 1 UZ? Fri, 20 June 2003 15:13 Go to previous message
Back to the 1UZ quickly - given that it's an alloy block - are the bores coated with some funky friction reducer, or are they LS1 style iron liners? I've only ever seen photos of an over-bored block, and couldn't tell wtfs going on Sad
Previous Topic:will Springs and Dampers from a RA23 fit into my TA22??
Next Topic:I need wheel offsets, im going nuts!!!!
Current Time: Thu Nov 19 08:38:49 UTC 2026
Total time taken to generate the page: 0.0069079399108887 seconds
