Toymods » Tech & Conversions » Quick specs - 1UZ-FE Vs 7M-GTE
biased99
Quick specs - 1UZ-FE Vs 7M-GTE Wed, 18 June 2003 23:49 Go to next message
Guys, I need stock power/torque figures for the 7M-GTE in stock trim.
Also, I need to know if this engine came in an MA70 Supra with the same differential as was behind a 7M-GE I suspect this to be the case, but need it confirmed by the Supra die-hards.
For comparison's sake, 1UZ's figures are as follows:
Power: 195KW
Torque: 353NM
Re: Quick specs - 1UZ-FE Vs 7M-GTE Wed, 18 June 2003 23:58 Go to previous messageGo to next message
7M-GTE DOHC 4/50 90 2954* 236@5600 253@3200 83 91 8.4:1 5psi/0.35bar JP
http://www.geocities.com/MotorCity/Pit/9975/engine pix/powercurves/7M-GTEU.gif
Less on both counts.
Re: Quick specs - 1UZ-FE Vs 7M-GTE Thu, 19 June 2003 03:32 Go to previous messageGo to next message
All MA70's came with a G series diffs, but the ratios are different for NA and turbo models.
biased99
Re: Quick specs - 1UZ-FE Vs 7M-GTE Thu, 19 June 2003 06:23 Go to previous messageGo to next message
gianttomato wrote on Thu, 19 June 2003 09:58
*scratches head* From this, am I to to take it that the 7M-GTE made:
236KW at 5600 RPM and,
253NM at 3200 RPM?
Surely that can't be right, can it? (Or am I reading it wrong?)
BlackSupra
Re: Quick specs - 1UZ-FE Vs 7M-GTE Thu, 19 June 2003 06:29 Go to previous messageGo to next message
236 hp
254 lb ft of torque
RA28
Re: Quick specs - 1UZ-FE Vs 7M-GTE Thu, 19 June 2003 06:34 Go to previous messageGo to next message
I'd say it's Hp as opposed to KW, and lb-ft instead of nm.
Tim
biased99
Re: Quick specs - 1UZ-FE Vs 7M-GTE Thu, 19 June 2003 12:03 Go to previous messageGo to next message
Yes, that would explain it...Can anyone do a quick conversion of hp to kw and ft/lbs to Nm? (just so that I can compare "apples with apples" Smile )
Thanks for the replies thus far...
manipulate
Re: Quick specs - 1UZ-FE Vs 7M-GTE Thu, 19 June 2003 12:06 Go to previous message
236 Hp = 176 KW
i use the number 1.34
HP/1.34 = KW
KW x 1.34 = HP
so yeah
176 KW
Previous Topic:ZZ Conversion
Next Topic:which GZE?
Current Time: Fri Nov 20 00:33:19 UTC 2026
Total time taken to generate the page: 0.0096900463104248 seconds
