Toymods » Tech & Conversions » which GZE?
papercut
which GZE? Thu, 19 June 2003 05:17 Go to next message
Hi all,
I own a KE25 corolla with a 4AGZE inside. I'm new to these engines, and also puzzled as to which version it is. I've heard there are like 5 versions? What does a MAP sensor look like/located and what does it do?
Well, to describe it abit, i have the Air Flow Meter attached to the air filter, twin coil packs, 4-2-1 extractors, a supercharger light on the dash and 'newer' looking top cover with the 'supercharger' font on it.
Has anyone got figures for these engines?
thnks
Gremlin
Maroubra
Re: which GZE? Thu, 19 June 2003 06:37 Go to previous messageGo to next message
G'day,
First of all, nice choice of car... i love the older rolla's
Secondly, the easiest way to describe a gze is the colour. Mine is a "red" top. it also has the AFM, not the MAP sensor. You'll find that most of the later model GZE's are MAP sensored, not AFM.
I'm not entirely sure on what car's they originally came out of... i just say red top Smile
Try this site
http://www.club4ag.com/faq%20and%20tech_pages/4A-G ZE_specs.htm
I'm not 100% confident that it's accurate though... maybe someone else can answer that question for the both of us!?!?!
[Updated on: Thu, 19 June 2003 06:41]
pulcino
Mackay QLD
Re: which GZE? Thu, 19 June 2003 11:06 Go to previous messageGo to next message
What happened if sombody just painted the cam covers that colour?
One way to tell the difference between a big port gze and a small port gze is whether or not it runs a dizzy. Small port gze came out with coil packs and crank angle scensors and somewhere along the line recieved the coated pistons.The gze with the dizzy was normally a big port and has semmiforged piston non oil squirter with 8:1 comp ratio ( lower than small port.
feral4mr2
Bundaberg, Qld.
Re: which GZE? Thu, 19 June 2003 11:21 Go to previous message
Freakif it has the AFM with the twin coil pack then it's a bigport 8.0:1 compression 4agze. that type of ze came mostly from the Levin's.
Previous Topic:Quick specs - 1UZ-FE Vs 7M-GTE
Next Topic:3sgte into a st185 sx
Current Time: Fri Nov 20 00:43:01 UTC 2026
Total time taken to generate the page: 0.0065560340881348 seconds
