Toymods » Tech & Conversions » 1UZFE into a TA22. question
Alainve
Newcastle NSW
icon7.gif  1UZFE into a TA22. question Sat, 29 June 2002 11:16 Go to next message
Nod im thinking about puting a 1UZFE into my TA22(im also consiering many others too)i have seen a member here has done it and would like to know just what is involved, is there any parts that need to be fabricated other than engine mounts? which gearbox is used if not the stock item.
Drift on! Laughing
Grant
Newcastle, NSW, Australia
Re: 1UZFE into a TA22. question Sat, 29 June 2002 11:50 Go to previous messageGo to next message
Unfortunately in NSW this conversion illegal. My understanding is that Jamie lives on the NSW/VIC border so gets the mod passed under VIC law.
1UZ FTE
Re: 1UZFE into a TA22. question Mon, 01 July 2002 22:42 Go to previous messageGo to next message
There is a lot to be considered in the conversion and a lot that needs modifying
eg sump, steering box to clear rear exhaust port' alternator, engine mounts, oil filter location, Radiator, maybe front swaybar shape depending on how u set up the alternator and sump
If u want to run a manual then Gearbox adaption plate or new bellhousing, flywheel, clutch assembly, rear crossmember and this will inturn alter tailshaft length
Height location is the most critical as the cank clears the crossmember by about 10mm and the inlet plenum clears the bonnet by about 10mm
but in total they fit rather well when in the bay
Grant is right i live on the Vic NSW Border and the car is registered in Vic
If u would like to know more detail about the conversion let me know as i have heaps of modified pics that i can email u
Hope this helps u make a decision
jamie
chrisss
melb
Re: 1UZFE into a TA22. question Tue, 02 July 2002 15:43 Go to previous messageGo to next message
how does it go?
ever had it down the 1/4?
what was the cost of the basic conversion?
did it affect the balance/ handling much?
do you think a sr20det or 3sgte conversion would be cheaper/better?
1UZ FTE
Re: 1UZFE into a TA22. question Thu, 04 July 2002 00:59 Go to previous messageGo to next message
It goes great
1/4 mile time, not officially, only on the stop watch so until officially i will keep the time to myself
Cost wasn't that much as did most of the work myself and with a few mates dearest part was the engine then clutch assembly, most of the other stuff i already had so say around the $2000 - $2500 figure
The balance and handling i am working on at the moment to get right as i am unhappy with this part of the car more so the handling side of things
don't know about the other conversions as i have never done these
but apparently a 3sgte can be a bit tricky to get in a 22
[Updated on: Thu, 04 July 2002 01:00]
chrisss
melb
Re: 1UZFE into a TA22. question Thu, 04 July 2002 10:06 Go to previous messageGo to next message
so your running a manual box with it are you?
I thought those V8's were only autos - so you used a custom flywheel and bellhousing?
are you running factory computer? if so how does it cope with a different gearbox?
1UZ FTE
Re: 1UZFE into a TA22. question Thu, 04 July 2002 23:14 Go to previous messageGo to next message
yes the box is a w58 with a bellhosing from dellow and it was a very good quality casting
the flywheel was made by myself
The injection is run by a Haltech computer
Yher i think u are right in saying they only come as Auto's but i could be corrected on this
biased99
Re: 1UZFE into a TA22. question Thu, 04 July 2002 23:59 Go to previous messageGo to next message
No, you are correct...
1UZ-FEs only ever came as autos, with the A340 transmissions...
I for one would definitely like some more info on your car, as I am determined to do a 1UZ into (something, not sure what), if/when I sell my Soarer...I'd like to know how your car goes.
1UZ FTE
Re: 1UZFE into a TA22. question Fri, 05 July 2002 00:26 Go to previous messageGo to next message
No prob
More than happy to tell u what i can about the conversion
if u like email me direct
j@yackandandah.com
KDog
Re: 1UZFE into a TA22. question Wed, 17 July 2002 04:43 Go to previous messageGo to next message
Yeah the 1uzfe only came with auto trans A341E and A342E. If you want to use an aftermarket ECU I can recommend the Autronic. I also have a small ECU which can control the gearshifts on the Auto trans "tiptronic". So you push a button to change up a gear and another to change down a gear.
1UZ FTE
Re: 1UZFE into a TA22. question Wed, 17 July 2002 05:41 Go to previous messageGo to next message
KDog
Any chance of getting u to email me off list more details about your tiptronic conversion have been looking into this myself with a little PLC
j@yackandandah.com
jamie
KDog
Re: 1UZFE into a TA22. question Thu, 18 July 2002 03:22 Go to previous message
I don't know if you will have much chance using a PLC. Two of the solenoids you need to control are analogue, not just on/off. You also need to be able to calculate inputs such as engine load, speed and do some processing.
Toyota have all the info you need it it will be much more accurate than anything I can provide. Find the manuals for a LS400, UCF10 they should have all the info you require in the automatic trans section. This is where I found my info.
Previous Topic:jap turbo kits?
Next Topic:Ma70 - Auto 2 Manual, 1jz conv
Current Time: Mon Oct 19 18:04:31 UTC 2026
Total time taken to generate the page: 0.0050649642944336 seconds
