Toymods » Tech & Conversions » 44mm 18rg and 2tg
ta2272
44mm 18rg and 2tg Thu, 19 June 2003 06:19 Go to next message
will 18rg 44mm carbs fit my 2tg manifold??? (solex)
Jason
CelicaRA45
nth ringwood, Victoria
Re: 44mm 18rg and 2tg Thu, 19 June 2003 07:05 Go to previous messageGo to next message
you sure there 44mm solexes 18rg and 2tg had 40mm std ,but trd mucked around with the 44 mikunis
inferno
Re: 44mm 18rg and 2tg Thu, 19 June 2003 08:30 Go to previous messageGo to next message
Since the 18RG engine has larger bores, the distance between the two carbies is larger than the distance between them on a 2TG. Some modifications to the "equalizer bars" between the carbies are required. You could modify them yourself with some difficulty, but your better off using the throttle linkages off the 2TG carbies (just bolt off and replace). The bolt patterns are the same, and mechanical linkages may need some minor adjustment. 18RG carbies run well on a 2TG, provided they have been jetted and tuned accordingly.
I think celicara45 is right, 18RG solexes are 40mm.
Snyper
Re: 44mm 18rg and 2tg Thu, 19 June 2003 11:09 Go to previous messageGo to next message
ok, just a thought....
**18rg and 2tg had 40mm std**
**18RG carbies run well on a 2TG, provided they have been jetted and tuned accordingly.**
Ok.... if they are the same carbies on a 2tg, and the same on a 18rg, then why put 18rg carbies onto a 2tg if they are going to be the same ?! sounds like a bit of hassle and mucking around rather than just getting the existing set of carbies tuned properly, I know they go out of tune and out of sync. with each other eventually, but the money is worth being spent on good tuning...
Oh, and I obviously don't know how to use the "quote" button properly either..
Brendon
inferno
Re: 44mm 18rg and 2tg Thu, 19 June 2003 11:49 Go to previous messageGo to next message
Theres always one smartass in the group.. Twisted Evil Laughing Laughing
Snyper wrote on Thu, 19 June 2003 20:39
I do!! Its the button with "Quote" written on it Very Happy . hehe.
Apparently the first generation of solexs toyota used on their 2TGs worked better and had less difficulties than the 18RG solexes. Personally I would prefer to use 2TG solexs but someone's g/friend took them off me Shocked
alwaysRA23
Re: 44mm 18rg and 2tg Thu, 19 June 2003 14:29 Go to previous messageGo to next message
i always thought that the 18rg standard carbies were 44mm solexs
well at least thats what i was always told,
but i guess i stand corrected Confused
Re: 44mm 18rg and 2tg Thu, 19 June 2003 23:02 Go to previous messageGo to next message
18R-G = 40mm
2T-G = 38mm
Snyper
Re: 44mm 18rg and 2tg Fri, 20 June 2003 02:43 Go to previous messageGo to next message
ok, let's get things right, for once rob, hehe
she is my ex gf, and she owned them for her engine anyway, not that the engine is going... haha
Brendon
mckejon
Re: 44mm 18rg and 2tg Fri, 20 June 2003 04:09 Go to previous messageGo to next message
Norbie wrote on Fri, 20 June 2003 09:02
18R-G = 40mm
2T-G = 38mm
Are you sure about this Norbie cos it definitaly says in my workshop manual that the 2T-G has 40mm throttle bore. Rolling Eyes
Re: 44mm 18rg and 2tg Fri, 20 June 2003 10:40 Go to previous messageGo to next message
Well my 2T-G had 38mm carbies... there were different versions of the 2T-G though.
CelicaRA45
Re: 44mm 18rg and 2tg Fri, 20 June 2003 13:27 Go to previous messageGo to next message
all 2tg had 40mm you wernt measuring the chokes were you norbs 1st model had 30mm next had 32 and the last 1 had 38mm chokes and they were 40mm solexes they made 40 and 44 ph mikunis and i think also 48mm
juzzo84
Hornsby, N.S.W
Re: 44mm 18rg and 2tg Fri, 20 June 2003 22:46 Go to previous messageGo to next message
40mm solex carbs gt celica
thetoyman75
Club President
icon10.gif  Re: 44mm 18rg and 2tg Sun, 22 June 2003 23:47 Go to previous messageGo to next message
All the sidedraft Solex-Mikuni 2T-G carbs were 40mm. It will even say 40 on the casing. 18R-G memory is not as Good and I have my manual out on lone but the 18R-G did get 44 Solex Mikunis.
CelicaRA45
Re: 44mm 18rg and 2tg Mon, 23 June 2003 06:49 Go to previous messageGo to next message
sorry only came out with 40mm and 34 chokes and 170 airs and 145 mains and 60 pumps and that was the top of the range 9.7to 1 piston 18rg non pollution engine 44 mm mikunis were put on by some1 else as these motors had to have some fuel economy
IRA11Y
Club Member
Re: 44mm 18rg and 2tg Mon, 23 June 2003 07:12 Go to previous messageGo to next message
well ive got a 40mm and a 48mm solex set(after the fake inner to bring it down to 40mm is pulled out Smile ) sitting on my bench in a few days i can take a pic if anyone wants?
CelicaRA45
Re: 44mm 18rg and 2tg Mon, 23 June 2003 07:18 Go to previous messageGo to next message
michael we are talking about the butterfly size not sleave they bolt inside it self
IRA11Y
Club Member
Re: 44mm 18rg and 2tg Mon, 23 June 2003 07:29 Go to previous message
oops sorry both mine are 40mm in that case Embarassed
Previous Topic:2 more GZE wiring Q's
Next Topic:Taking off cover of cam gear on 4AGE?
Current Time: Tue Oct 20 23:48:32 UTC 2026
Total time taken to generate the page: 0.032012939453125 seconds
