Toymods » Tech & Conversions » 3sgte injectors
gabe
3sgte injectors Thu, 19 June 2003 14:36 Go to next message
does anyone know how big the standard st185 injectors are and what impedance they are??
Re: 3sgte injectors Fri, 20 June 2003 00:01 Go to previous messageGo to next message
I think they are 440cc or there abouts..
I'd like to know what larger ones fit! Maybe 13B 550cc?
Classique71
Colac, Victoria
Re: 3sgte injectors Fri, 20 June 2003 02:40 Go to previous messageGo to next message
i think the denso 540cc Supra ones off the 2jzgte fir into the 3sgte rail ..
They are about 200 + each though i believe - Will get details tonite
JustenGT4
Re: 3sgte injectors Fri, 20 June 2003 04:45 Go to previous messageGo to next message
Yup, the American spec sypra injectors are 540 and are a straight replacement. They are all high impedance from memory (13 ohm). 13B ones are no good as they are end feed and low impedance. You could do it be more work than it's worth. ST205 injectors are also 540s and a straight replacement. Apart from that you have to go aftermarket which is hell expensive.
Re: 3sgte injectors Fri, 20 June 2003 06:57 Go to previous messageGo to next message
Cool thanks for that info! Looks like i need to hunt around for some 205 or 2jz injectors then.. Bit hard being only the american model.. is there an easy way to tell them apart?
Joel
juzzo84
Hornsby, N.S.W
Re: 3sgte injectors Fri, 20 June 2003 08:56 Go to previous messageGo to next message
i think the 3sge injecotrs are about 13.4 ohm
justin
JustenGT4
Re: 3sgte injectors Sun, 22 June 2003 22:12 Go to previous messageGo to next message
Joel,
Yup there is an easy way to pick what you want. The stock side feed 440s have either a light grey or very dark grey body. The 540cc supra injectors are a light purple and the 205s are a dark brownie maroon. Each is easily different from the others. The 205s are the best to get as they have a better spray pattern than the supra injectors from memory....harder to find though
[mikey]
Re: 3sgte injectors Tue, 24 June 2003 02:52 Go to previous messageGo to next message
hmm they should be low impedance...there is a resistor in the system for those cars.
JustenGT4
Re: 3sgte injectors Tue, 24 June 2003 02:55 Go to previous message
Actually, i think you're right Michael...it's the n/a 3SGE that has the high impedance injectors. Or could just be the onset of senility -)
Previous Topic:Where do I rebuild my engine in the ACT??
Next Topic:GZE interheater?
Current Time: Tue Oct 27 10:14:44 UTC 2026
Total time taken to generate the page: 0.10696792602539 seconds
