Toymods » Tech & Conversions » 4AGE probs
Hirogen
Melbourne, Australia
      WTF is a jabber?
4AGE probs Fri, 20 June 2003 06:32 Go to next message
Ok, got the 4AGE into my sprinter, its all hooked up n shit. It turns over but wont fire. Had fuel, spark and ive checked the timing. Someone please help?
Re: 4AGE probs Fri, 20 June 2003 06:55 Go to previous messageGo to next message
Have you confirmed if the injectors are opening?
When you say got fuel, do you mean the fuel pump is running and fuel in the rail.. But need to check if it's coming out of the injectors.
Joel
YelloRolla
On your mum!
icon14.gif  Re: 4AGE probs Fri, 20 June 2003 07:08 Go to previous messageGo to next message
A good way to get the injectors opening and closing is to give them a bump with a metal rod while someone cranks the engine over.
Re: 4AGE probs Fri, 20 June 2003 07:18 Go to previous messageGo to next message
One thing i've found to make the job easier of testing if they are opening or not is to pull the dizzy out, and with ignition on, spin it around..
This makes it easier to hear if the injectors are pulsing as there is no other noises with cranking etc.
Hirogen
      WTF is a jabber?
Re: 4AGE probs Fri, 20 June 2003 12:38 Go to previous messageGo to next message
Ok, it seems the injectors are firing. The only thing that i havnt hooked up is the O2 sensor. Everything else looks fine, and yeah theres till fuel and spark, and the timing is fine. Anyone have any other suggestions? Crying or Very Sad
SPRINTAH!
Re: 4AGE probs Sun, 22 June 2003 04:27 Go to previous message
have you had the engine in pieces?
spray some start ya bastard in the throttle body, if it fires then you have a fuel problem.
maybe the cam timing is rooted, just a thought.
Richard
Previous Topic:Auto shift knobs
Next Topic:7MGTE leaking oil
Current Time: Thu Nov 19 21:56:04 UTC 2026
Total time taken to generate the page: 0.0062589645385742 seconds
