Toymods » Tech & Conversions » 7M-GTE Air Flow Meter
thefastj
7M-GTE Air Flow Meter Fri, 20 June 2003 07:11 Go to next message
who has one? Very Happy
i need to find out the exact size of the end of it.
preferably, how far apart the bolt holes are.
thanks!
7mgte83
Barossa valley SA
Re: 7M-GTE Air Flow Meter Fri, 20 June 2003 08:28 Go to previous messageGo to next message
the centre of the bolts are 100mm and 50mm apart.
hows that? Smile
thefastj
Re: 7M-GTE Air Flow Meter Fri, 20 June 2003 09:41 Go to previous messageGo to next message
champion!
that's what i wanted to hear! Cool
celicaboy_2000
Lismore, NSW
Re: 7M-GTE Air Flow Meter Fri, 20 June 2003 12:39 Go to previous messageGo to next message
Are you after one or just after the bolt pattern?
thefastj
Re: 7M-GTE Air Flow Meter Fri, 20 June 2003 12:52 Go to previous messageGo to next message
was just after the bolt pattern..
just making sure it was the same as the 1UZ's.
anyone know where i can get an adaptor for it to convert it to a round pipe (for a pod)?
or what can i make one out of?
i don't have welding skills!
Rattlehead
Re: 7M-GTE Air Flow Meter Fri, 20 June 2003 14:41 Go to previous messageGo to next message
Check around for the 1UZ AFM + 550cc injector upgrade...If u check out supraforums, I think theres a tech article about it.
7mgte83
Barossa valley SA
Re: 7M-GTE Air Flow Meter Sun, 22 June 2003 01:29 Go to previous messageGo to next message
As I said in the other thread, I made one out of stainless steel. I just went down to the local metal supplier and got them to cut me a flat piece the right size for the AFM and a few cm of 3" pipe. I took that to the guy that did my exaust and got him to tack weld the two pieces together (it would distort if mig welded completely) then went home, cut out the flat material in the middle and drilled holes for the bolts. I used a bit of silicone to make it airtight around the tack welds and made a gasket out of old inner tube.
Danners
Central Coast, NSW
Re: 7M-GTE Air Flow Meter Mon, 23 June 2003 00:27 Go to previous messageGo to next message
I could take a photo of mine for you if you like?
Dan
SUPRA MAN
Re: 7M-GTE Air Flow Meter Mon, 23 June 2003 15:41 Go to previous message
You can get an adapter for the 7MGTE air flow meter to make it a round pipe for only $4.50 US plus postage on EBAY.
Doesnt get much cheaper, or easier than that.
Previous Topic:7M-GTE (MZ20 Soarer) Problems
Next Topic:Microtech MTX12 (on a 3tgt)
Current Time: Sun Oct 25 08:05:22 UTC 2026
Total time taken to generate the page: 0.1037769317627 seconds
