Toymods » Tech & Conversions » Need some rear end specs please.
trent_kershaw
Need some rear end specs please. Fri, 20 June 2003 07:20 Go to next message
Hi guys....
I'd like to find out the answers to the following questions for a couple of different rear ends - GA70 supra and IS200.
What are their widths?
What are their brake setups?
F or G series diff?
Approximately how much should I expect to pay for these?
Thanks in advance
Trent Kershaw
Re: Need some rear end specs please. Fri, 20 June 2003 07:42 Go to previous message
GA70 is approx 1570 mm across hubface to hubface. It will be a G series diff (check to see that it is LSD). It will have a disc brake rear - end 291 mm ventilated rotors, single piston sliding caliper with an internal drum handbrake 190mm. I bought a complete rear end for about $450 and put the thing to good use in my Hilux rear end.
I can't tell you anything much about the IS200. They have solid rear discs (307 mm I think but check), twin piston caliper with an internal drum handbrake (also 190 mm).
Previous Topic:What cams for turbo 3t/2tg ?!
Next Topic:Removing axle seals? RA28.
Current Time: Thu Nov 19 09:54:10 UTC 2026
Total time taken to generate the page: 0.0061459541320801 seconds
