Toymods » Tech & Conversions » I need wheel offsets, im going nuts!!!!
79rollaboy
NSW Engadine
I need wheel offsets, im going nuts!!!! Fri, 20 June 2003 08:21 Go to next message
I cant figure out the offsets for my wheels,
They are to be for a RWD Corolla 79
also if someone has 16x7" or 17x7" wheels im seriously interested.
My stud pattern is 4x100
Re: I need wheel offsets, im going nuts!!!! Fri, 20 June 2003 10:29 Go to previous messageGo to next message
RWD Corolla's are 4x114.3mm.
manipulate
Re: I need wheel offsets, im going nuts!!!! Fri, 20 June 2003 10:31 Go to previous messageGo to next message
with stud patterns what does the 100 or 114.3 mm mean
i know the 4 means 4 studs
is the 2nd part the length of the stud ?
Re: I need wheel offsets, im going nuts!!!! Fri, 20 June 2003 10:37 Go to previous messageGo to next message
distance between the studs.
manipulate
Re: I need wheel offsets, im going nuts!!!! Fri, 20 June 2003 10:46 Go to previous messageGo to next message
ahhk
thanx mate
[Updated on: Fri, 20 June 2003 10:47]
Dodgy_Haro
Re: I need wheel offsets, im going nuts!!!! Fri, 20 June 2003 12:30 Go to previous message
Generally, most RWD cars like Sprinters and S13 Silvia's have a stud pattern of 4 x 114 PCD and off-set wise, you'd be looking for something around the +5 to +17 depending on rim width ... anything that's 4 x 100 PCD and around the +40 offset mark are usually FWD car alloys.
Check out the tyre bible for more info - it may not tell you what offsets suit you best but at least you'll be more enlightened about the topic:
http://www.chris-longhurst.com/carbibles/index.htm l?menu.html&tyre_bible.html
Previous Topic:do toyota make an alloy block engine besides the 1 UZ?
Next Topic:Would RA Celica Disc or MA61 (Rear) fit the AE86?
Current Time: Thu Nov 19 08:44:20 UTC 2026
Total time taken to generate the page: 0.0059859752655029 seconds
