Toymods » Tech & Conversions » turbo timer wiring
MR PLOW
neverland
turbo timer wiring Fri, 20 June 2003 10:50 Go to next message
hey there any one know where i can get tt wiring diagram from i.e net site or something.
btw its a FET tt if it helps
or if any one knows but
it has 5 wires.
red, black, white, blue, yellow.
how do i wire it up my understanding would be
red - power
black - earth
yello - ?
blue - ?
white - ?
and what size fuse would i use aswel
brad
[Updated on: Fri, 20 June 2003 11:12]
sideshow
Re: turbo timer wiring Fri, 20 June 2003 11:33 Go to previous messageGo to next message
what brand is it
most timers are
red is batt power
green is ignition
blue is ignition aswell
r one i recon yr wires will be
on yr ingnition switch
connect red to batt
yellow to ignition
blue to 2nd ignition if it has one or to accesories
black to earth
u dont run a fuse
white could be afew things either handbrake or rpm or speed
depends what options yr timer has
but try the red black and yellow and see if it works that way
MR PLOW
neverland
Re: turbo timer wiring Fri, 20 June 2003 12:14 Go to previous messageGo to next message
do i just connect the ignition wires striaght to hte ignition
sideshow
Re: turbo timer wiring Fri, 20 June 2003 12:39 Go to previous messageGo to next message
what car is it in
yes just splice into the main ignition wire coming of the ignition switch
if u tell me what car its for i might know the wire clours
MR PLOW
neverland
Re: turbo timer wiring Fri, 20 June 2003 13:01 Go to previous messageGo to next message
ae82 rolla
sideshow
Re: turbo timer wiring Fri, 20 June 2003 23:07 Go to previous messageGo to next message
ok on back of ingnition switch just after the 6 pin plug
do not cut any wire on the ignition
just join the red to the thick white wire it should be batt
join the yellow to the black/red trace
join the blue to black/orange trace
join black to earth
and the white wire left im not to sure
if u do the above and the turbo timer doesnt turn on try earthing the white wire if it turns on then the white wire might be for the handbrake
can u see what model the turbo timer is
St3ve_AE92
South of Wollongong
Re: turbo timer wiring Sat, 21 June 2003 03:05 Go to previous messageGo to next message
When did u go turbo??? Confused
MR PLOW
neverland
Re: turbo timer wiring Sat, 21 June 2003 04:21 Go to previous messageGo to next message
its a FET - TB-508
yeah steve its mainly for warm up as mine is a pig when is cold as it shits me when i have to be near my car warming it up at someones house.
MR PLOW
neverland
Re: turbo timer wiring Sat, 21 June 2003 11:26 Go to previous message
figured it out the yellow went to the black and orange instead of the blue one.
thanks heaps sideshow
brad
Previous Topic:4agze comp question?
Next Topic:solved
Current Time: Thu Nov 19 19:25:39 UTC 2026
Total time taken to generate the page: 0.0062789916992188 seconds
