Toymods » Tech & Conversions » 2tg larger valve head
ta2272
icon11.gif  2tg larger valve head Fri, 20 June 2003 12:12 Go to next message
hey i am buying a larger valve head of a newer 2tg, but on this site http://www.tassie.net.au/~jar/2tg-info.html it says that the newer engines and the oldere engine have the same sized valves. Confused i dont get it. it also says it has the same horsepower is it worth getting this new head.
thanks heeps
Jason Surprised
Snyper
Re: 2tg larger valve head Fri, 20 June 2003 12:51 Go to previous messageGo to next message
if you read carefully on that site, it is the first version 2tg, with the 220 head that has the smallest valve sizes...therfore any of the other heads will do, depending on what you're doing with the head, ie. carbs, efi.
Brendon
juzzo84
Hornsby, N.S.W
Re: 2tg larger valve head Fri, 20 June 2003 22:44 Go to previous messageGo to next message
talk to rod (thetoyman), im sure the #88260/#88261 are the large heads off the 2tgeu!!
justin
thetoyman75
Club President
icon10.gif  Re: 2T-G larger valve head Mon, 23 June 2003 00:01 Go to previous message
There is alot of info in these forums on the 2T-G heads.
The "small valve 2TG head was the first one 88220. After that that all had the same size valves. Read this thread for information overload !
http://forums.toymods.org.au/index.php?t=msg&t h=13182
When all else fails... Use the search option Wink
Previous Topic:will an 18R-GEU head fit an18R-C
Next Topic:22R pistons
Current Time: Fri Nov 20 04:56:49 UTC 2026
Total time taken to generate the page: 0.0049340724945068 seconds
