Toymods » Tech & Conversions » fuel for 4agze
fudge
fuel for 4agze Sat, 21 June 2003 02:33 Go to next message
just a simple question i HOPE someone can answer Smile
what kind of fuel should you run a '88 4agze on? can you run one on normal unleaded without damaging it or only premium? cheers
LadySX
Re: fuel for 4agze Sat, 21 June 2003 03:57 Go to previous messageGo to next message
It was made to run on 100 Octane in Japan, so in AUS I would suggest putting nothing in it than a 98 Octane fuel (Mobil Synergy or BP Ultimate).
fudge
Re: fuel for 4agze Sat, 21 June 2003 08:38 Go to previous messageGo to next message
i know that the second version of the 4agze required it, but are you sure about the first version?
LadySX
Re: fuel for 4agze Sat, 21 June 2003 08:42 Go to previous messageGo to next message
first version was also a release in Japan not AUS so it will be the same deal
JDM hachi
was adelaide now newcastle
Re: fuel for 4agze Sat, 21 June 2003 22:42 Go to previous messageGo to next message
when i wired up my gze, i recall seeing that some of them actually had a fuel selection switch (i think it was possibly the american version) which would allow it to run on standard unleaded/premium.
EVOSTi
cambo
      no
Re: fuel for 4agze Sun, 22 June 2003 07:18 Go to previous messageGo to next message
was probably a switch for advancing/retarding the timing. either way your better off running the higher octane stuff.
[Updated on: Sun, 22 June 2003 07:21]
Bugman
Re: fuel for 4agze Sun, 22 June 2003 07:43 Go to previous messageGo to next message
seriously if your gunna even bother having a performance motor you should run the best fuel available. at 10cents more a litre you shouldnt be worried about the cost, if you are, you shouldnt have got a motor with power.
fudge
Re: fuel for 4agze Sun, 22 June 2003 08:25 Go to previous messageGo to next message
the problem i have is getting pulp. i have to drive about 30 mins to get some. was wondering if it would be ok to run ulp if i dont have enough fuel to get to a servo with pulp. i figured with the lower comp than the 2nd gze and knock sensor i could get away with it Smile
fudge
Re: fuel for 4agze Sun, 22 June 2003 08:27 Go to previous messageGo to next message
LadySX
Re: fuel for 4agze Sun, 22 June 2003 08:43 Go to previous message
If you really dont have a choice at the time then i would only put in enough to get me to a servo to get some premium, but if you use normal unleaded, carry some Octane Booster with you in your car to use with the normal unleaded.
Previous Topic:Panel Question Part the same? Celica ra60, ra63, ra65, ma61, sa63 etc
Next Topic:84 supra rearend swap
Current Time: Fri Nov 20 00:03:50 UTC 2026
Total time taken to generate the page: 0.013151884078979 seconds
