Toymods » Tech & Conversions » 3s-gte into a sprinter
gabe
3s-gte into a sprinter Sat, 21 June 2003 05:47 Go to next message
As some of you guys already know, im putting a 3sgte into my sprinter. ive had a look at the head and i know which way the endine should lean but what i dont know is how much......i heard 15 deg but when i set it up in the engine bay it looks way too much....whats the go?? is less (ie 5 deg) ok??
gabe
TA22-3SGTE
MACKAY
Re: 3s-gte into a sprinter Sat, 21 June 2003 12:07 Go to previous messageGo to next message
Why lean it at all
manipulate
Re: 3s-gte into a sprinter Sat, 21 June 2003 12:23 Go to previous messageGo to next message
is the engine designed to be on a lean ?
u better make sure that this is ok to do first
Re: 3s-gte into a sprinter Sat, 21 June 2003 12:24 Go to previous messageGo to next message
manipulate wrote on Sat, 21 June 2003 22:23
Yes
manipulate
Re: 3s-gte into a sprinter Sat, 21 June 2003 12:40 Go to previous messageGo to next message
Sorted
I wouldnt suggest leaning it any less than what the manufacturer states.....although it may look awkward thats how it is
TA22-3SGTE
MACKAY
Re: 3s-gte into a sprinter Sat, 21 June 2003 13:09 Go to previous messageGo to next message
I'v been running mine without a lean for three years with no problems
manipulate
Re: 3s-gte into a sprinter Sat, 21 June 2003 13:15 Go to previous messageGo to next message
Hmmm.... if u want it upright just make sure its ok b4 u do so
having it on an angle would lower centre of gravity slightly too ....which is a good thing
[Updated on: Sat, 21 June 2003 13:17]
CelicaRA45
nth ringwood, Victoria
Re: 3s-gte into a sprinter Sat, 21 June 2003 13:32 Go to previous messageGo to next message
they 20mm out of level to the right looking at the frt of them set the box up 1st you will no what i mean what version 3sgte 165,185or 205
gabe
Re: 3s-gte into a sprinter Sun, 22 June 2003 04:25 Go to previous messageGo to next message
i have the st185 version.
i noticed the oil drain holes are only on the left side of the head(when looking at the engine front on) so i only assumed that a slight lean was in order.
the 20mm that CelicaRA45 is talking about is about 6 degrees so i might run with that
kingpin
Wollongong
Re: 3s-gte into a sprinter Wed, 13 August 2003 09:23 Go to previous messageGo to next message
hey what kind of costs would be involved in putting a 3s-gte into a sprinter?
and how much would it cost just to buy the engine?
Re: 3s-gte into a sprinter Wed, 13 August 2003 09:27 Go to previous messageGo to next message
gabe - that thing is going to be a weapon when it's done! can't wait to see it's taillights disappearing
JustenGT4
Re: 3s-gte into a sprinter Thu, 14 August 2003 03:41 Go to previous message
I'm with 3SGTE-TA22. I've done the same conversion and just sat the engine upright. There are NO oil drainage problems but you do need to enlarge the sump capacity. Seeing you have to mod the sump anyway it's no problem.
If you do run a lean what are you going to do for a bellhousing???? Leaning the engine leans the gearbox, makes using the shifter a bit tricky Smile
Previous Topic:Original TA22 to get a 2TG!!
Next Topic:Wheel Offset for Celica GT4
Current Time: Sat Oct 24 06:57:23 UTC 2026
Total time taken to generate the page: 0.0051000118255615 seconds
