Toymods » Tech & Conversions » 20 valve conversion in ae93
cam_RA40
Launceston, Tasmania
haha, funny little head!
20 valve conversion in ae93 Sat, 21 June 2003 23:22 Go to next message
Hello, i am currently planning my 20 valve conversion in my ae93 (sx) corolla. The car currently has a 16 valve 4age. I'm just trying to find out some of the problems that I might run in to. I understand that the exhaust manifold is different so that will need to be sorted out. can i use my current gear box? what other things will need to be changed that won't just bolt up?
thanks, any advice is greatly appreciated.
EvilJack
Sutho/Hills NSW
Re: 20 valve conversion in ae93 Sun, 22 June 2003 00:27 Go to previous messageGo to next message
everything will bolt up.
you can even use the 20v gearbox.
the wiring is just the tricky bit but there are plenty of ppl who could do it in a few hrs.
Cool
cam_RA40
Re: 20 valve conversion in ae93 Sun, 22 June 2003 00:33 Go to previous messageGo to next message
so are the 16v and 20v gear boxes identical? & am i right in beleiving that the exhaust manifolds are different? so this should only really be a weekend job to get it running?
also does anyone know of any decent 20 valves for sale? or know of a decent importer to purchase one from (no front cut) that also has good prices?
cameron
EvilJack
Sutho/Hills NSW
Re: 20 valve conversion in ae93 Sun, 22 June 2003 02:11 Go to previous messageGo to next message
the gearbox's are different but only in the ratios i htink.
smallport is c50 and silvertop is c52.
the exhaust manifolds are slightly diff but why is this a prob? just swap the whole motor over.
it can be done in a weekend in a sx easy. Just make sure your preperation is well prepared.
Cool
cam_RA40
Re: 20 valve conversion in ae93 Sun, 22 June 2003 05:54 Go to previous messageGo to next message
all sounds good so far. all i've got to do is find an engine Smile I have seen the for around the $1000 mark from some importers although i am sure that they are available slightly cheeper. also, what does a stock 16 valve sell for these days? as i will get rid of mine once i have the new engine. Anyone know where i could purchase some 'sx twincam 20' stickers to replace the 'sx twincam 16' stickers on my doors and hatch?
NuGeN
Re: 20 valve conversion in ae93 Sun, 22 June 2003 07:56 Go to previous messageGo to next message
20 valve gearbox bolts straight up...?
I heard that you need to modify the crossmember to fit in...
but don't quote me on that...
Hunty
Re: 20 valve conversion in ae93 Sun, 22 June 2003 11:00 Go to previous message
i think you only need to modify the cross member when putting in the GZE and GZE box
Previous Topic:Power vs Reliabilty
Next Topic:3TGTE head gasket
Current Time: Fri Nov 20 02:16:27 UTC 2026
Total time taken to generate the page: 0.097229957580566 seconds
