Toymods » Tech & Conversions » Cleaning rusted water jackets
BlackSupra
Cleaning rusted water jackets Sun, 22 June 2003 14:18 Go to next message
Now i 'hear' that rusted water jackets are a big issue in the 7mgte block.
How does one go about cleaning these out with having to dissasemble the bottom end?
As terrbile and stupid and crazy as it sounds, would it be possible to run rust converter/remover through the coolant system. Or would this majorly destroy something?
I don't wish to rebuild the bottom end just to attend to rusted coolant channels. (assuming there are some)
ta guys.
ed_ma61
Lost in the K hole
Re: Cleaning rusted water jackets Sun, 22 June 2003 22:56 Go to previous messageGo to next message
BlackSupra wrote on Mon, 23 June 2003 00:18
good luck Rolling Eyes
it really takes a screwdriver and a wire bottle brush to get the scale out (theyre big and chunky mineral deposits - and a bit of rust too, but nothing at all like a mild surface rust).
theres no way to scrape the flakes and big chunks (of which there will be many) out of the block wthout taking off the head, timing cover, and knocking out the welch plugs...
Grega
melbourne.victoria.austra...
Re: Cleaning rusted water jackets Sun, 22 June 2003 23:18 Go to previous messageGo to next message
i made a device which you plug the hose into and plug compressed it into with an air tap - so you can blast air/water in and clean things out.
you get pretty wet, but, it works well.
BlackSupra
Re: Cleaning rusted water jackets Sun, 22 June 2003 23:31 Go to previous messageGo to next message
I new that would be the case, but what im saying is, can it be done without touching the bottom end, ie leaving pistons, crank etc in the block? Rolling Eyes
Grega- so its almost a 'karcher' type device (high pressure water cleaner) is it?
And will it matter if the cylinder walls got wet in this process above the pistons, or is it a matterof leaving the bottom end out int he sun for a bit after that?
ta guys.
ed_ma61
Lost in the K hole
Re: Cleaning rusted water jackets Sun, 22 June 2003 23:35 Go to previous messageGo to next message
oh yeah, you can leave the pistons in etc. just pack the bores full of newspaper and tape the top over.
ed_ma61
Lost in the K hole
Re: Cleaning rusted water jackets Sun, 22 June 2003 23:37 Go to previous messageGo to next message
realistically tho, if youve got the block out and are playing with it, youd be best to do 'other' stuff to the block too - like deck it. this will require the crank being out of the block anyway...
BlackSupra
Re: Cleaning rusted water jackets Sun, 22 June 2003 23:49 Go to previous messageGo to next message
engine will be pulled from a halfcut
but to deck the block one must remove the pistons yes?
ed_ma61
Lost in the K hole
Re: Cleaning rusted water jackets Sun, 22 June 2003 23:53 Go to previous messageGo to next message
yep Very Happy
BlackSupra
Re: Cleaning rusted water jackets Mon, 23 June 2003 00:00 Go to previous messageGo to next message
Now new rings is not what i want
realistically i wanted a straight swap over with a change of headgasket and some tighter ARP studs or bolts maybe.
P.S ED 'polished'
Grega
Re: Cleaning rusted water jackets Mon, 23 June 2003 10:50 Go to previous messageGo to next message
nah blacksupra, it uses compressed air from my air compressor, so, a little different (well VERY different in design) but similar principle.
BlackSupra
Re: Cleaning rusted water jackets Mon, 23 June 2003 10:52 Go to previous message
I think you need to illustrate this with some pics Very Happy
Previous Topic:Help, suggestions!
Next Topic:Legality of engine conversions?
Current Time: Thu Oct 22 14:04:08 UTC 2026
Total time taken to generate the page: 0.0062470436096191 seconds
