Toymods » Tech & Conversions » Can you believe this 1JZ?
jza70-mel
Perth WA
Can you believe this 1JZ? Sun, 30 June 2002 07:15 Go to next message
Can you believe this guy?
http://www.southfloridatuners.com/c&n_performa nce/neil/main.htm
He's running stock 1jz-gte toyota computer after upgrading his turbo to a T-78!
The fueling mods he must have are fuel pump, and (probably) injectors. He seems to control the whole lot with the (Old style) Apexi-AFC and fuel pressure regulator.
I guess you don't NEED aftermarket management to run huge turbos, but he's probably not making a whole lot of power he could have (especially with the nitrous).
Re: Can you believe this 1JZ? Sun, 30 June 2002 12:32 Go to previous message
I'd say that he's not so much holding back his top end power figure, but with the sized injectors required to make that sort of grunt and fuelling only modified by a crude interceptor, my guess is it'd run like a filthy black-smoking, rough, fuel pouring pig at anything other than full throttle, 5000+rpm, which is when you'd hafta get both paws on the wheel Very Happy
Previous Topic:Engine removal AW11
Next Topic:Million dollar question
Current Time: Sat Oct 31 02:05:57 UTC 2026
Total time taken to generate the page: 0.0038859844207764 seconds
