Toymods » Tech & Conversions » Big Fuel Filters?
Dylo
icon5.gif  Big Fuel Filters? Mon, 23 June 2003 05:20 Go to next message
Ok ive been running around today looking for a big inline fuel filter for my new fuel setup, but all the idiots in the shops have been tellin me that its impossible.
I need a 1/2 inch inline filter and so far the only ones ive found, you need to have fuel lines that actually screw into the filter!
Anyone know where i can get a basic one? my pump has a half inch feed, so i assume there must be a filter for it! C'mon those 1UZ boys must be using huge lines and filters!!!?
Re: Big Fuel Filters? Mon, 23 June 2003 05:33 Go to previous messageGo to next message
I got one from a 300zx .. It has just the standard barb type fittings on each end that fuel line slides onto. Its 8mm fittings though.
Dylo
Re: Big Fuel Filters? Tue, 24 June 2003 09:18 Go to previous messageGo to next message
C'mon guys! im sure some one will know if there is such a filter.
its the only thing holding me up before my car runs properly! so im pretty damn keen to find out if i can get this filter!
What do hugely worked V8's use then? im sure they would need 1/2 inch fuel lines and therefor a half inch filter!?
Re: Big Fuel Filters? Tue, 24 June 2003 10:28 Go to previous messageGo to next message
why not use two smaller ones, then a reducing T piece? easy then to source the filters and double capacity. all ya need is two T adaptors, and a few bits of fuel line...
3t-RA40
Re: Big Fuel Filters? Wed, 25 June 2003 00:31 Go to previous messageGo to next message
Why do you want to run 1/2" fuel lines? I think you'll find most (not all) of us who have done a conversion would have used 8mm fuel lines. Even the guys running 1js and 1uz.
Re: Big Fuel Filters? Wed, 25 June 2003 00:49 Go to previous messageGo to next message
Yeah my 8mm lines supply 4x 550cc injectors fine and thats on 20 psi boost.
Dylo
Re: Big Fuel Filters? Wed, 25 June 2003 07:23 Go to previous messageGo to next message
Yeah im not using 1/2 inch thru the whole thing, its just the inlet of my hi-pressure pump is half inch, and it is fed from the bottom of my surge tank which is also half inch.
The reason i want a filter in this line is a mate of mine killed 3 pumps before he figured that it was tiny bits of weld & shit comming from inside his surge tank. I dont want this, so i figure a filter in the 1/2 inch feed is the go.
Any other ideas?
Re: Big Fuel Filters? Wed, 25 June 2003 07:30 Go to previous messageGo to next message
I might be wrong but didn't think you could put a filter before the hiflow pump. I thought it had to go after it?
They are gravity fed and don't like feeding through the filter.
Don't you have a prime pump? Put it before that if so. Then put the filter after the hiflow pump.
Joel
Dylo
Re: Big Fuel Filters? Wed, 25 June 2003 09:55 Go to previous messageGo to next message
Yeah, im not sure about how the gravity feed will go thru the filter i was just gonna test the differences in flow rates with and without the filter to see how it goes.
Maybe i will just have to blast out my surge tank and hope that no tiny flecks of weld or rubbish come from inside the tank?
marc00013390
vic
Re: Big Fuel Filters? Wed, 25 June 2003 13:58 Go to previous messageGo to next message
from memory i think an efi falcon ea or eb uses a filter
that is quite large, and has nipples rather than screw-ins.
check between the throttle-body inj and multi-point inj versions
[Updated on: Wed, 25 June 2003 14:00]
Dylo
Re: Big Fuel Filters? Thu, 26 June 2003 01:56 Go to previous messageGo to next message
Ahh thanx alot for that, i will have to check it out. Anyone else seen large filters in anything?
ae101rKev
West Aust
Re: Big Fuel Filters? Thu, 26 June 2003 03:47 Go to previous messageGo to next message
My 6cyl ED is not a 1/2inch line, maybe the V8 has a different setup.
Ryco does make 1/2inch filter, I should be able to get the part number early next week.
Kev
Dylo
Re: Big Fuel Filters? Thu, 26 June 2003 07:32 Go to previous messageGo to next message
Kev,
That would be great if you could find out, Thanx. Repco were telling me Ryco dont make one, and thats all they will stock
BigWorm
Toymods Board Member
Turramurra, Sydney.
Re: Big Fuel Filters? Fri, 27 June 2003 11:19 Go to previous messageGo to next message
I'm pretty sure you'll run risk of killing your pump by putting a filter infront of it, the whole idea of the surge tank is to provide it with an unrestricted & constant flow, so it doesn't have to suck, it only has to push.
If you look at any factory EFI pump they have big mesh strainers on the pump inlets (I'm talking about in-tank pumps here) that would stop big stuff getting through but would cause no restriction to flow.
Just make sure you give the surge tank a really good rinse out before installing it, I'd be suprised if there was much loose material inside, unless the welding was really dodgy. And run a low pressure fuel filter infront of the low pressure pump, & this will protect both pumps.
Dylo
Re: Big Fuel Filters? Sat, 28 June 2003 03:28 Go to previous messageGo to next message
Yeah thanks guys i have decided just to really blast out my surge tank, and hope that will be enough.
Phill@Pittwater B&C
North Narrabeen, Sydney.
Re: Big Fuel Filters? Sun, 29 June 2003 08:41 Go to previous messageGo to next message
I agree with joel but if you do need a 1/2 inch in line fuel
filter then i have some mercedes benz filters in stock. You will,
however, have to take a trip to your local ENZED, KWIKFIX or
other hose fitting specialist and buy some 1/2 inch threaded
tails to screw into it. These sell for around the $4 - $5 mark
and the filter is worth around $20. Definately use a plastic
in line filter before the low pressure pump though.
Ryco No. Z15 is 5/16 and Z153 is 3/8. Hope this helps. Phill.
ae101rKev
West Aust
Re: Big Fuel Filters? Thu, 03 July 2003 07:54 Go to previous messageGo to next message
Having a few probs getting this part number for ya
Its a metal Ryco one
This is where my mate gets his from
KWINANA AUTO ONE
Kwinana Trades & Commercial Cntr
Shop 23 Meares Ave Parmelia 6167
Ph (08) 9439 2293
Fax (08) 9419 2290
Give them a call, they stock both disposable and reusable ones.
My mate runs it between the fuel tank and swirl pot/surge tank on his drag torana.
Hope this helps.
Kev
Dylo
Re: Big Fuel Filters? Thu, 03 July 2003 10:05 Go to previous message
Thanx alot mate, i have sorted the matter now.
Cheers everyone
Previous Topic:urgent!!
Next Topic:possible to get a RB26DETT GTR into a TA22?
Current Time: Sun Oct 25 23:22:50 UTC 2026
Total time taken to generate the page: 0.0049281120300293 seconds
