Toymods » Tech & Conversions » W55 box - Spline OD and teeth?
W55 box - Spline OD and teeth? Tue, 24 June 2003 02:54 Go to next message
Hello, does anyone know the OD diameter and teeth of a W55 box? On the spline.
It's to help a clutch place work out what kind of clutch is avaliable for my conversion (3sgte into RA28).
Joel
CelicaRA45
nth ringwood, Victoria
Re: W55 box - Spline OD and teeth? Tue, 24 June 2003 06:10 Go to previous messageGo to next message
joel get a SA63 h/duty clutch disc and h/duty pressure plate to fit that model also
Re: W55 box - Spline OD and teeth? Tue, 24 June 2003 06:18 Go to previous messageGo to next message
The guy I was talking to at Western Clutch (has a good rep), said that the SA63 is 27 OD and 20 teeth on the spline... But i've been led to believe the W55 is 29mm OD and 21 teeth.
Bit confusing........
Re: W55 box - Spline OD and teeth? Tue, 24 June 2003 06:24 Go to previous messageGo to next message
The W58 clutch plate I have (should be the same as W55) is 21 spline with 29mm OD teeth.
My suspicion is that they are quoting you the spline dimensions for an ST141 Corona which ran that dreadful Borg Warner 4 speed.
[Updated on: Tue, 24 June 2003 06:28]
Re: W55 box - Spline OD and teeth? Wed, 25 June 2003 01:06 Go to previous messageGo to next message
Yah... my w55 is 21/29
As for the bogwarmer 4 speed... what a box Very Happy
Re: W55 box - Spline OD and teeth? Wed, 25 June 2003 01:59 Go to previous message
Thanks all, much appriciated! I can confidently quote 21/29.
Previous Topic:Engine Dampers
Next Topic:How do you fix or repair a stuck open thermostat??
Current Time: Thu Oct 29 23:54:41 UTC 2026
Total time taken to generate the page: 0.0049090385437012 seconds
